the_coupe's NA engine build thread
Old Jan 19, 2011 | 01:43 AM
Equipped4dr's Avatar
Nice build. Im in for the win
Old Jan 19, 2011 | 03:15 AM
Tollboothwilley's Avatar
Originally Posted by the_coupe
lol i cracked my very first one too. i just lined it with silicone and it hasnt leaked since and its been atleast a year since i put the longblock in that m35x. if you know some one who can weld aluminum, get it fixed esp if hes plannin on painting it cuz it will leak more likely.
You could use some JB weld too That stuff is pretty damn strong. aluminum weld is the right way to do it though
Old Jan 19, 2011 | 10:19 PM
the_sedan's Avatar
lol true. so i gave my buddy the paint and covers to paint so hopefully they'll be done tomorrow. pix will be the update im already starting to feel the pressure from how much ive already spent and how much more i have to spend :/ now accepting paypal donations
Old Jan 20, 2011 | 04:47 PM
Frankieg35's Avatar
He is just gonna buy a new cover.. Not taking any chances..
Old Jan 21, 2011 | 09:21 PM
the_sedan's Avatar
bla bla bla.....so all of my stuff is expected by friday next week. and my friend worked a lil more majik today. i so happy!
Old Jan 24, 2011 | 06:13 PM
the_sedan's Avatar
plastigaged the mains earlier and im within the .0015 range and spec is .0014-.0018 so im runnin std acl main bearings, gotta wait for my manley rods to show up to spec them out. stay tuned folks.......pix of what shows up this week and then it starts gettin nasty
Old Jan 25, 2011 | 05:23 PM
Frankieg35's Avatar
Lookin good so far!!
Old Jan 25, 2011 | 05:32 PM
G35Buzz's Avatar
If the covers look that good I can't wait till this is finished... In for the Win!!!
Old Jan 26, 2011 | 04:48 PM
the_sedan's Avatar
so on this post i will update all the money i've spent just so everybody can get a rough estimate on the cost of a mild build...minus labor since i am capable to perform such work .
btw, i just ordered ACL race rod/main bearings and thrust washers...all STD size.
my price list:
BC stage2 cams, springs, Ti retainers - $1150
CP 96mm 11:1 pistons and Manley rods - $1075
ACL rod/main bearings and thrust washers - $140
Revup oil pump - $153
Water pump - NC
Thermostat - NC
Pathy coolant bypass mod - $187
Master gasket kit - $235
External bottom end balance - $180
Cylinder bore job - $125
Forged TQ plate rental - $115
File fit rings - $35
Machine block for HR mod - $65
Stillen crank pulley (stock size) - $90
Competition stage4 clutch/flywheel kit - $300
/\new clutch disc - $165
Resurfaced flywheel - $40
Resurfaced heads - $60
HR headgaskets - NC
HR headbolts - NC
OEM main bolts - NC
OEM crank pulley bolt -
OEM flywheel bolts - $28
OEM clutch pivot ball - NC
OEM release bearing - $35
OEM spark plugs - $60
OEM t-chain tensioners - $170
MR used long tube headers - $150
break-in oil - $30
VHT red wrinkle paint (2 cans) - $18
HT paint (5 cans)- $35
CIN tune - $500
Old Jan 27, 2011 | 07:58 PM
the_sedan's Avatar
so my revup oil pump came in yesterday, the master gasket kit comes in tomorrow. and my BC stuff came in todayyyyyyyyy
i think imma skip on doing a valve job since this motor has low mileage. just gonna clean it all up real good. so in that case, i'll put the BC stuff on, bolt the cams down and check the valve clearances. BUT i have a good feeling the heads will start seeing some port work after the weekend
Old Jan 27, 2011 | 08:11 PM
GreenGoblin's Avatar
The goblin resurrection
looking good so far.
Old Jan 27, 2011 | 08:38 PM
the_sedan's Avatar
speak of the goblin, did you have any valve lash adjustments when you installed your cams?
Old Jan 28, 2011 | 08:32 PM
the_sedan's Avatar
yummy yummy! manley h-beam rods and acl race bearings (rods, mains, thrust washers)
the master gasket kit came in today as well as some new flywheel bolts, crank pulley bolt, and pilot bushing. i have a brand new pivot ball already in my tool box.
and some new pix i took since i washed her up and shined the tires after work today
Old Jan 31, 2011 | 07:34 PM
the_sedan's Avatar
Old Jan 31, 2011 | 07:37 PM
  #30
Frankieg35's Avatar
Nice!! Your saving a lot doing the labor yourself..
