the_coupe's NA engine build thread
Old Jun 17, 2011 | 09:34 AM
  #106
the_sedan's Avatar
thanks guys, but you are wrong frankster....too much hassle....new harness, ecm, bla bla bla no
and herrschaft, yes indeed!
Old Jun 19, 2011 | 11:33 PM
  #107
the_sedan's Avatar
only took me roughly 2 hours to get the motor/trans dropped on friday after work.
and at the same time my buddy finished porting the intake manifold, but the lower plenum isnt finished so you will see in the pics i have a non-painted lower installed for now.
gettin ready to put the motor on the crossmember
got started on the swap around 10am saturday. ended up gettin home around 2am. this included swapping all the parts on, i painted all the brackets/solenoids/plenums, AND did the wire tuck AND spent over an hour tryna get the coolant system bled (which was a royal PITA btw)
but this is the final result....for now still got more stuffs to do
Old Jun 19, 2011 | 11:43 PM
  #108
Frankieg35's Avatar
Should of done the pulley delete mod.. booo!!
Old Jun 19, 2011 | 11:50 PM
  #109
the_sedan's Avatar
i did.......? you blind foo
Old Jun 20, 2011 | 12:03 AM
  #110
Frankieg35's Avatar
I am actually.. haha I looked real quick cause it wasn't that impressive.. ooohhhh!!!!
Old Jun 20, 2011 | 12:50 AM
  #111
Lone Wolf's Avatar
Great work!! Very nice!
Old Jun 20, 2011 | 12:33 PM
  #112
Sylvan lake V35's Avatar
Looks good Is the stillen crank pulley dampened?
Old Jun 20, 2011 | 11:01 PM
  #113
the_sedan's Avatar
imma be up that way within the next couple weeks so imma oohhhhhhh you! lol
thanks guys and it doesnt appear to be sylvan.....but i gave the machinist the complete rotating assembly from the pulley bolt back to the flywheel bolts to get balanced. so far i like how quickly it revs!
had a lil issue with it smoking, turns out this motor doesnt like a drilled out pcv valve if you are still routing to the plenum for the vacuum source. was filling up the catch can. now i have a new oem pcv valve on and no more smoking or filling up the catch can doh!
osiris tune setup at CIN this saturday for those who want to come chill with me while they do their magic!
Old Jun 20, 2011 | 11:07 PM
  #114
Frankieg35's Avatar
Haha!! U coming up to jersey??
Old Jun 20, 2011 | 11:28 PM
  #115
the_sedan's Avatar
yeah, plannin on it. ill keep you and dan posted
Old Jun 20, 2011 | 11:29 PM
  #116
Frankieg35's Avatar
Yeah man def!!! U gotta see dans car..
Old Jun 21, 2011 | 12:28 AM
  #117
HotRodG35's Avatar
Nice Progress, But like Sylvan I had the same question, ditched my KJR Crank Pulley and went back to OEM crank pulley for piece of mind.
Hope the machinist didn't balance bottom end with flywheel, VQ is internally balanced and will be a nightmare to replace flywheel.
Good luck with the tune, curious to see Dyno results
Old Jun 21, 2011 | 11:12 PM
  #118
the_sedan's Avatar
yeah i understand it may be internally balanced but thats all out the window once you throw aftermarket internals on it. cant wait for the tune on saturday, will def have vids from the outside and sheets for proof.
Old Jun 26, 2011 | 12:46 AM
  #119
herrschaft's Avatar
Don't forget to update this thread too
Old Jun 26, 2011 | 01:02 PM
  #120
the_sedan's Avatar
i know i know
lets start off with she dyno'd 281/242 as is before the tune. AFRs were here and there. so then there was the tuning session oh yeah, and the car was so loud that it would ring your ears if you were within 20ft from the car when it was doing a pull
welp, she made a lousy 310 hp/274 tq . it was a rather warm day, in the 90s, and the intake air temps were around 110-120*F. the 310hp pull had an iat of 112*. she didnt make any power past 6400 so the limiter was set to 6800. more than likely due to the plenums and MR long tubes, but i dont have that kinda money to dish out on cosworth and sg parts but i had a stock lower plenum on, so when i finish modifying the one i have at work, that will go on along with a walbro pump and maybe put on a stillen airbox/filter and see what diff she makes on a cooler day.
either way, she feels way better, i can def fill a bigggg midrange bump in power. im still tryna get used to NOT having to keep the idles up so the car wont die when i come to a stop tho lol. ben did have to kick the idle up to almost 1000rpm or else the car would cut off if you rev'd up and let the idle settle.
some pix and a couple vids for your eyes
all strapped down
ben gettin everything hooked up
anything to help cool her down
ben doin his thing...takin a smoke break
the chart
4th gear pull
5th gear pull
