Leaking coolant, water pump, timing chain tensioner.
Old Feb 28, 2012 | 10:58 AM
JZ's Avatar
JZ
G35 Coupe KY0
wow! Had I known this I would have done this myself. well maybe, im still not convinced i can play with the timing chain though. I just replaced the thermostat on my own and took it to the dealer for a waterpump replacement. Mine was leaking from the waterpump cover. I paid over $700 this past weekend. Idk if they changed the chain tensioner though, i know they removed that cover because I can see leftover silicone on it. Ill call in and ask.
Old Feb 28, 2012 | 11:01 AM
Xx AzN xX's Avatar
nice, you saved a ton of money!!!
Old Jul 16, 2017 | 10:47 PM
luis1029's Avatar
Exclamation Hello, How do you fix the leak?
Same here
Old Jul 16, 2017 | 10:49 PM
luis1029's Avatar
Exclamation Hello, How do you fix the leak? ...
Old May 30, 2019 | 05:59 AM
Built George's Avatar
infiniti
Question
Originally Posted by medianjoe
I changed the water pump today. I followed the service manual.
Tools)
- 19mm socket (to rotate the crankshaft)
- M8 - 1.25mm pitch - 80mm length bolt, 2EA (to pull out the water pump)
- Sockets, drivers, socket extension, ...
My car just passed 110k miles. Tensioner was in good condition but I replaced it because of chain noise for 0.5~1 sec at cold start in the morning. Water pump was also in excellent condition. The problem was the o-rings.
Timing chain & guide. Wow.
Attachment 241272
New water pump installed.
Attachment 241273
New timing chain tensioner installed. (Part#: 13070-EY00A)
Attachment 241274
Do you have to set timing to tdc when changing water pump ?
Old May 30, 2019 | 02:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I recommend you read the section of the FSM, it's under CO - Cooling. It's sort of a tedious and nonstandard process.
https://nicoclub.com/archives/infini...e-manuals.html
Joshua615
Aug 31, 2015 12:29 AM
Smittie20
Aug 9, 2015 04:29 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
