Gauges suggestions
Old Jan 28, 2011 | 03:41 AM
whoisthis's Avatar
Gauges suggestions
i'm just trying to get the idea of how much gauges cost, and what are decent.
All i need is A/F ratio (no wideband since expensive), or exhaust temp, oil temp., and coolant temp. since i autoX on N/A car. No recording or playback function needed. Just simple very instant update.
Which guages are sold for decent price that a student can afford? Which means no Defi lol. i'm looking at this UltraGauge but i'm afraid it doesn't update gauges very instantly. http://www.ultra-gauge.com/ultragauge/index.htm Couple 350z guys have it but not so much review on them.
Old Jan 28, 2011 | 08:36 PM
Shakuya88's Avatar
A couple things. First I have Glowshift gauges, fast update, they do have peak and warning functions. They have the look of defi (MIN is straight down then goes around to have MAX at the right.)
www.glowshiftdirect.com
Also, you can't do a narrow band gauge unless you have test pipes. They use the factory sensor and don't come with one (reason they are cheap) But our factory upstreams (before cats) are wideband. Glowshift has some "cheaper" wideband gauges, but I don't know if I would trust that, for my wideband I have autometer.
Old Jan 28, 2011 | 08:44 PM
whoisthis's Avatar
If i were to get the individual oil temp gauge, does it come with everything i need to get it to work? like do you need the sandwitch plate under the oil filter?
Old Feb 1, 2011 | 05:21 AM
andrewstclair's Avatar
i dont think any oil temp gauges come witth a sandwich plate they all usually come with a sensor and an assortment of npt adapters you would have to find a place to mount it. just curious why would you bother puttin in a A/F gauge if its not gonna be a wideband? it will only tell you the ratio at idle wich is kinda useless. and the dash has a coolant gauge. right next to the oil filter there is the factory oil press sender you can take it out and put in a t-fitting and put in your own oil temp n oil press gauges
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Rose M
Oct 12, 2015 10:00 AM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
9tray turbo
Sep 29, 2015 10:22 PM
