... WAIT A MINUTE... or maybe...?
Old Apr 20, 2011 | 10:42 AM
thatattguy's Avatar
Hey,
Im installing a motordyne iso copper plenum spacer and its the 5/16 size. What im lost on is how it came with 1/2 plastic spacers for the middle.
Is that correct or did i get the wrong plastic spacers??
Old Apr 20, 2011 | 11:22 AM
Hi-TechG35's Avatar
I believe that is how it comes bro. The plastic spacers are the same because the screws that go back into the upper plenum are the same. The spacer itself is what changes in size.
Old Apr 20, 2011 | 05:32 PM
thatattguy's Avatar
You where correct! thanks! Now i FORGOT to remove the "guide bolts" that face upward in the plenum. I dont have a leak from what i can tell, will this be okay?
One on eatch side.
Old Apr 20, 2011 | 06:36 PM
thatattguy's Avatar
And this is a very dumb question but what direction to I remove the guide bolt?? From the top side I attatch the 4mm socket or the bottom side?
Old Apr 20, 2011 | 06:41 PM
thatattguy's Avatar
Anybody who helps me will be my hero I swear haha.
Old Apr 21, 2011 | 10:46 AM
Tollboothwilley's Avatar
you should remove those "guide bolts" and use the screws that came with it
remove from the top side - if you dont have a star then just use a small socket
Old Apr 22, 2011 | 11:02 PM
the_sedan's Avatar
the spacers arent really that tall cuz if you saw, they are recessed some so they seat against the inside of the plenum where the bolts go through. and i cant remember what size the 2 studs are but they are a small star/torx bit, take them out and put the same (as the others all around) size bolts in and you're done. make sure you tightened them all in sequence and to proper torque!
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Darrick Au
Sep 14, 2015 12:10 AM
