Engine Rebuilt advice for Heads on Revup
Old Apr 30, 2011 | 11:18 PM
faiz23's Avatar
Hey Members,
I am looking at a vehicle currently and the engine sounds like it needs some parts replaced and machine work on the top end. If you hear the car it sounds like a Turbo Diesel from VW. I want you to listed to the sound and tell me what you think is the issue and the cost to fix it. I am guessing it needs new shims and needs to work done on lifters or head. I am guessing an easy $1000- $1500. It might be better just to get a low mileage motor then deal with one that has OC issues and was driven hard.
http://s124.photobucket.com/albums/p...430_195555.mp4
http://s124.photobucket.com/albums/p...430_195715.mp4
https://g35driver.com/forums/g35-sed...maybe-tdi.html
Old Dec 29, 2011 | 11:34 PM
stephen_s's Avatar
did you end up rebuilding it?
Old Dec 30, 2011 | 12:00 AM
faiz23's Avatar
No hell no I ran from that car since it sounds like total crap and was toast. I paid more for a vehicle with service records, infiniti extended warranty and lower mileage. If I had a vehicle that needed a motor replaced then I would give a call to HAL at DYNOSTY.
https://g35driver.com/forums/forced-...ll-b-enuf.html
Engine packages are customizable to match your goals. Here are two samples of common configurations:
Stage 1 Short Block packages start at $2765 and include CP Pistons, Eagle Rods, ACL Bearings, machining, align hone, balance, blueprint and pro assembly!
Stage 1 Long Block packages start at $3690 and include the Stage1 Short Block, ARP L19 Head Studs, ARP Main Studs, Cometic Head Gaskets, Mill & Clean Heads and assembly.
http://my350z.com/forum/engine/51070...ur-engine.html
http://www.importpartspro.com/shblpa.html
http://www.importpartspro.com/headpackages.html
http://www.importpartspro.com/vqloblpa.html
Frankieg35
Mar 20, 2016 09:42 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
linedr89
Aug 17, 2015 05:11 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
