problem with door locks
Old Nov 19, 2004 | 10:38 AM
alsg35's Avatar
G SQUAD
I woke up this morning and started the car. So far So Good. Went into house for one minute and came out to car, with the engine on, the car was locked. I did have a second key and unlocked it. I removed the key and locked the door. I then open the door with the remote and started the car and the car automatic lock the doors, again. I have a up window mod installed about two months, with no problem. I also have a cut off switch install for my amp about one month ago, with no problems.
The dealer is going to look into for my. Does anyone have any idear, what it can by. Help
Old Nov 19, 2004 | 01:15 PM
Msedanman's Avatar
O.F. Administrator
Re: problem with door locks
That function runs thru the BCM. If there's a problem with it, the dealer should be able to detect it with a Consult II scanner.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Nov 19, 2004 | 04:20 PM
dave's Avatar
If you have the window up mod from KP Technologies, it can be set to lock the doors automatically.
If you want to turn that off, I think it goes something like this:
1. Leave door open for the entire procedure.
2. Put key in ignition, turn it on.
3. Click lock 3 times
Or you could just try disconnecting the negative battery terminal for a minute.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Nov 19, 2004 | 08:22 PM
alsg35's Avatar
G SQUAD
Dave: You hit it right on the head. That was the problem. Thanks.
Allan
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
RA081024
Aug 18, 2015 07:03 AM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
