oil cooler and/or high capacity pan
Old Jun 24, 2011 | 04:48 AM
whoisthis's Avatar
hi, i have some questions to ask.
right now, i have Stillen high capacity oil pan on my 350z. i noticed that at drifting events, oil pressure drops about 15 psi after couple sliding. The psi continues to drop if i continue. i was drifting for 6 hours, taking little cool down after each run.
Which one does better job in cooling and/or protecting the engine from high heat, .5qt/1qt oil cooler or 1 qt high capacity pan?
i'd love to have both but 7 qts every oil change is too much for mostly daily driven car.
My other question is, since now i put 6 qts, can i change the oil more later than when i used to put 5 qts?
Old Jul 11, 2011 | 11:17 PM
Eric@TCGMiami's Avatar
WOW, old thread saddened to see no one has chimed in.
Well, here are some notions to go by:
Chances are that your pressure is going down because of temperature. The higher the temp the thinner the oil. Adding more oil to your engine in the means of expanding the capacity does assist in cooling and oil change intervals but not by much. A physical oil cooler would provide better results.
Some dumb simple math and DO NOT HOLD ME TO THIS, but it's just an estimated guess.
The normal interval for oil changes is 3000 miles. We have a total of 5 quarts. If you divide 3000 / 5 = 600 miles. So for every quart it'll be safe to say the oil should be advanced 600 miles.
3000 / 5 = 600
So if you add an additional quart I would change it no later than 3,600 miles. 7 quarts 4,200.00. Some people change it later, some sooner. I for one change my oil every 2,000 miles.
It's totally on you.
Old Jul 11, 2011 | 11:32 PM
whoisthis's Avatar
3000 / 5 = 600
thanks for your reply.
It would be more beneficial to go back to stock pan and add an oil cooler that can hold extra 1 qt, right?
Do you know anything about oil temperature gauge? i'm thinking about adding one but don't know where to get the oil temperature sensor and everything. i never found a DIY. Also, not sure if i should put the sensor in the oil filter spacer or into the oil pan itself.
Old Jul 11, 2011 | 11:38 PM
Since you have the spacer, just keep it. It'll add an additional .5 to 1 quart of oil in the system. I actually found this thread as I am searching for oil coolers. So my reply to this is yes it will help by adding a cooler.
You may say/ask why add another quart it'll be more expensive every oil change. my simple reply to that is what is 1 quart of oil $8 - 10.00 ? .... How much is a rod bearing replacement?
As for the oil temperature sensor. You'd have to give me a few minutes to locate the manual to find the pin out for the ECU which you can rob the signal from.
Old Jul 11, 2011 | 11:47 PM
Check out this thread
https://g35driver.com/forums/tuner-d...technical.html
Post 3 has all the pin outs for the ECU's
Old Jul 12, 2011 | 12:05 AM
whoisthis's Avatar
instead of this way, i'd rather have a sensor dip into the engine oil to be more accurate.
So this can be done by putting a sensor through the pan or into the oil filter spacer (i have to get this spacer anyways if i go w engine oil cooler)
still not decided if i want to keep the stillen oil pan. i don't think an extra qt of oil on top of an extra qt help that much...hmm
Old Apr 9, 2013 | 08:09 AM
AhmadH's Avatar
if im gonna buy an oil cooler, i have to buy also an oil filter spacer???
Old Apr 9, 2013 | 09:02 AM
HotRodG35's Avatar
If your referring to oil sandwich plate/adapter than yes, or can purchase complete kit that has the fittings, hoses and adapter plate included for cooler.
Its cheaper to purchase adapters, fittings seperately and assemble hoses yourself.
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Kicknshift
Sep 3, 2015 09:35 AM
yankeefix
Lighting
Aug 24, 2015 04:12 AM
itztwinki3
Aug 11, 2015 05:52 AM
