Clutch engaging point aways very low?
Old Jul 30, 2011 | 10:30 AM
batanatoly's Avatar
Unhappy Clutch engaging point aways very low?
My clutch pedal feels normal and no issue with that, but my engaging point is always, always very low I did try to adjusted by the turning the master cylinder pivot but it doesn’t change it it’s stays very low.
I hope someone had that problem before, because I have been searching for a months, but it seems that everyone have high engaging point not low. Few months ago replace master and slave cylinder and put DOT4 fluid due to sticking clutch pedal, actually the pedal was different when is cold or hot. Every morning the clutch pedal was half way down with very low engaging point, and after it worms up the pedal gets the normal operation. But all that is fix by replacing master and slave.
But now the problem is that I can’t adjust it; I turn the master cylinder pivot all the way out and all the way in but nothing changes the engagement point. Btw new clutch was put in 20k miles ago, and the clutch is fine no problem with that only the engaging point is my issue.
I hope someone can help me with that, any ideals.
Thank You.
chinee
Jun 10, 2024 07:48 PM
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
TurboEE
Jul 31, 2015 10:41 AM
vstypicals
Jul 20, 2015 10:55 PM
