Oil Consumption I have it, What should I do???
Old Aug 3, 2011 | 12:46 PM
Jstache23's Avatar
I got it help please, 2004 G35 6spd/navi package. I going through oil like crazy. I live in NJ so local help would be nice.
Old Aug 3, 2011 | 05:27 PM
R6n350GT's Avatar
Check your #6 spark plug tube (on drivers side) and if full of oil then u need new valve cover seal and i would get some thin washers to but under the bolts so you can increase the torque of the screw. ACtually just check all apark plug tubes.
Also you should do a compression test in all cylinders and if one or two are low do a leak down test, you may need new rings
Check you PCV valve is ok, check there is pressure getting to it via the line
Thats all i can think of at the moment.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
