Clutch Cooler?
Old Aug 30, 2011 | 04:25 PM
P10 WRC's Avatar
Question Clutch Cooler?
Hello,
So i live in phx and it gets ****ing hot in the summer. Even with regular bleeding of my clutch fluid, i am sometimes still plagued by the "sticky clutch pedal" issue.
From reading the posts, it is caused when the brake fluid in the clutch system gets to hot and boils. Does anyone make a cooler for this? I know nismo makes a power steering cooler. Could that be modified and used on the clutch fluid instead?
here is the nismo unit
http://www.g35parts.com/G35-350z-NIS...790-rsz30u.htm
don't flame me if my question is stupid. I want to take the car to the track some day and don't want to worry about this issue there and risk ****ing up my clutch.
thanks
marty
Old Aug 30, 2011 | 07:09 PM
brandon1978's Avatar
Clutch fluid doesn't circulate, so adding that type of cooler won't help.
Old Aug 31, 2011 | 04:20 PM
Dark-Knight's Avatar
Was contemplating the same thing. Good point Brandon, thanks.
Old Sep 3, 2011 | 03:22 PM
bikinilust's Avatar
Upgrade the clutch fluid?
I know if u see higher temps w brakes, u upgrade the brake fluid to dot 4...
Not sure about the clutch
Or how about putting a better heat shield arount the clutchline to reduce heat soak from the headers
Old Sep 3, 2011 | 11:58 PM
I get the 'sticky clutch pedal' problem when the fluid gets old. I flush it completely about every two years, which is when the problem will just start happening again. I don't trust anything other than a complete two person flush done the way specified in the service manual.
I've heard some can't solve the problem without replacing the cylinder, but I can't remember if it was the slave or master that went bad. If I had to guess, it would be the slave.
Old Sep 26, 2011 | 07:16 PM
P10 WRC's Avatar
there has to be a way to prevent this from coming back. i have it still happen from time to time even after the fluid change. i live in az and am scared to take my car to the track now.
what about something like this?
http://www.offroadproductsllc.com/in...es/Page596.htm
Old Sep 26, 2011 | 07:25 PM
Vegas4DR's Avatar
You can do 2 things:
#1) wrap the lines with heat shielding tape/material
#2) upgrade the fluid to something with a higher boiling point
Both of these things will help, but I would start with heat wrap/shielding first
Old Sep 26, 2011 | 07:40 PM
P10 WRC's Avatar
well, i guess some racing brake fluid is in order and a full bleed of the old stuff
Old Sep 26, 2011 | 08:00 PM
Vegas4DR's Avatar
don't underestimate the heat shield materials as well. As close as the clutch line runs to the exhaust there is a lot of heat that leeches in.
Old Sep 28, 2011 | 12:38 AM
Sylvan lake V35's Avatar
Nismo makes a stainless steel clutch line that comes heat wrapped
Old Sep 28, 2011 | 11:41 AM
I had the SS clutch line from Z1 installed by my local wrench last week, they also adjusted my clutch pedal up a lil. So far not one stuck pedal or mushy feel after several hard launches to redline and 100+ temps during my road trip this weekend. Could have found the real fix for my stupid clutch system. I'm boosted with a recently installed JWT clutch and flywheel combo as well, and had a bleed and flush done after it was installed. Hope this helps guys.
Old Oct 5, 2011 | 12:54 AM
Canadian's Avatar
Canada, eh?
I have forged performance ss clutch line. it is wrapped in some sort of heat wrap, $50..definitely recommended. just did a vegas summer and had no issues with it.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
Usman Ali
Sep 22, 2015 06:59 AM
UT G35
Sep 3, 2015 03:58 PM
