OC Stock block rebuild question? Help needed.
Old Sep 4, 2011 | 01:32 PM
citymunky's Avatar
Red face OC Stock block rebuild question? Help needed.
Old Sep 4, 2011 | 02:05 PM
faiz23's Avatar
You can use 96mm pistons that are slightly oversized compared to stock 95.5mm(I think). You can bore out the cylinder to fit the larger piston and rings to fix the oil consumption issues. Change out valve steam guide seal and use the HR gasket. You can do couple cooling mods in the process to help the block with temps. Read some of these builds and that should help you out. Also spend lots of time on my350z since they are extremely focused on modding, Forced induction and engine builds.
http://my350z.com/forum/na-builds/52...manley-bc.html
Old Sep 4, 2011 | 02:18 PM
citymunky's Avatar
Gookiecrunch
Aug 19, 2015 12:00 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
LuisGee
Aug 5, 2015 01:27 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
