VQ35DE Engine Bay Bolt Sizes
Old Jan 14, 2012 | 04:34 PM
redpearl99's Avatar
Update:
In case you are wondering what grade SS bolts are required to replace OEM bolts, I have learned that the weird markings on some OEM bolts are actually Nissan's OEM bolt grades. However, not all OEM bolts have these markings
Nissan OEM Bolt Grades:
7T ("7") = 8.8
9T ("9") = 9.8
10T ("10") = 10.9
12T ("12") = 12.9
Old May 2, 2012 | 02:00 PM
redpearl99's Avatar
CORRECTION:
Throttle body bolts are M6 x 55mm, they are NOT M6 x45mm
Old Aug 14, 2012 | 12:24 AM
MPG35fiend's Avatar
thanks for the sticky
plan on installing a polished upper plenum and a polished timing cover and want to replace old corroded ones for stainless steel ones.... what are the main bolts and screws i need to replace?
sorry for the noob question, just started researching and trying to find a shortcut to the answer. since I'm trading parts with Vivek id like to send him my old parts asap for him.
Old Oct 4, 2012 | 12:28 PM
G35Papa's Avatar
Great sticky
Does anyone know if 50mm or 60mm would work with a spacer? The bolts I'm looking at don't come in 55mm
Upper Plenum : ( 9 )6mm x 25mm - (3 )6mm x 45mm - ( 4 )6mm x 60mm - (2)6mm nuts
Using a plenum spacer, add 10mm to length to all bolts
Thanks!
I winded up buying the 60mm and they fit just fine with my 5/16" spacer.
Old Oct 27, 2012 | 08:53 PM
neo_anderson302's Avatar
Does anyone know the size of the engine cover Nuts and bolts? I just broke one.
2 Nuts
2 bolts
Old Nov 1, 2012 | 03:15 AM
04 Blue G35's Avatar
Originally Posted by G35Papa
Great sticky
Thanks!
+1 I also would like to know this
Old Nov 1, 2012 | 11:30 AM
G35Papa's Avatar
I forgot I had posted this
Old Nov 1, 2012 | 11:32 AM
G35Papa's Avatar
2 Nuts
2 bolts
You can use m6 bolts/nuts to replace those.
Old Dec 8, 2012 | 01:11 AM
ZGagnon's Avatar
anybody know the best place to buy all these?
gonna need to make a nice purchase of almost all listed at some point
Old Dec 8, 2012 | 02:04 AM
G35Papa's Avatar
Here's a couple of sources I've used before
http://dmpfasteners.com/
http://www.allensfasteners.com/
You can also buy dress up kits from R1 Autoworks
https://g35driver.com/forums/engine-...ml#post6631278
Old Sep 23, 2014 | 08:20 PM
Shanes_G's Avatar
Bolts, 12-Point Head, Stainless 300, Polished, 6mm x 1.00 RH Thread, 25mm UHL
Is this correct for the timing cover?
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
