Water pump cover metal tab
Old Dec 26, 2011 | 12:50 AM
redpearl99's Avatar
can someone tell me what's the use of this tab? I'm painting my covers so I wanted to know if I can grind off this tab before painting
In the second pic you can see there an indent for the tab on the opposite side of the cover
Old Jan 8, 2012 | 06:24 PM
redpearl99's Avatar
bump
Old Jan 18, 2012 | 04:56 AM
HotRodG35's Avatar
Its the timing mark.
Old Jan 28, 2012 | 05:27 PM
redpearl99's Avatar
So does that mean i shouldn't remove it?
Old Jan 29, 2012 | 12:02 AM
GreenGoblin's Avatar
The goblin resurrection
No you should leave it, if you ever had to time your motor you would need to align it to the mark.
Old Jan 29, 2012 | 07:13 PM
Sylvan lake V35's Avatar
It serves no purpose, you time the car with the covers off anyway. Mine has has the timing set about 4 times now and this cover was no part of the process.
The only purpose I see it serving is when you put the covers on it may point to the key way on your crank, by then our timing is already set. I have never used it for anything. That being said I wouldn't remove it because if you sand it off you will end up with a hole do to the indent on the other side.
Old Jan 30, 2012 | 05:45 AM
HotRodG35's Avatar
In reference to the factory service manual the tab on cover is for timing. Whether you have used it or not thats what its for.
lil beezy
Lights
Nov 16, 2015 02:52 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
junon
Sep 5, 2015 10:40 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
G35CO
Sep 4, 2015 09:27 AM
