most important z-tube alteration!!!
Old Dec 30, 2004 | 04:11 PM
baileyrx's Avatar
This may help some newbies & old timers alike. When you install your z-tube with a new air filter, you may not notice that it is dangerously close to an air conditioning line, which when rubbed by the metal clamp will rupture!!! don't forget to try to hold clamp & tube away from this line when tightening bolts, also for added peace of mind, install some type of rubber or plastic cover over air conditioning line to help prevent problems.
See picture.
I know this has been talked about before, but I never hurts to be repeated.
Old Dec 30, 2004 | 04:24 PM
Msedanman's Avatar
O.F. Administrator
Good point and thanks for the reminder.
Some have found out the hard (expensive) way that the clamp will chafe away at that A/C line and eventually wear thru.
Old Dec 30, 2004 | 10:14 PM
Aznteazer's Avatar
if u have just the z-tube and stock air box, then i dont think u need to worry about the rubbing.
*edit: but i did anyway just in case after i saw that big post.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
wow600rr
Sep 28, 2015 11:50 AM
wayneside
SouthEast
Sep 23, 2015 06:38 AM
