waterpump @ 77k?
Old Jan 28, 2012 | 04:58 PM
JZ's Avatar
JZ
G35 Coupe KY0
waterpump @ 77k?
Just got an oilchange at the dealer and the service advisor said my waterpump is leaking. Could this happen at such low mileage? Or is he bs'ing me... Its an 03.5 coupe
Old Jan 28, 2012 | 05:06 PM
herrschaft's Avatar
Anything is possible. I would go and inspect the pump to see if it actually was leaking.
Old Jan 29, 2012 | 05:40 PM
JZ's Avatar
JZ
G35 Coupe KY0
I smell antifreeze sometimrs after driving. never overheated though
Old Jan 29, 2012 | 06:07 PM
redpearl99's Avatar
let's hope it isn't the water pump, the labour to replace one of those things is absolute hell
Old Feb 4, 2012 | 06:13 PM
JZ's Avatar
JZ
G35 Coupe KY0
Yea... Stealership said 760. The part is only 150-200. Im going to have somone else look at it
Old Feb 4, 2012 | 06:35 PM
bluedevils95's Avatar
Have R&J look at it tonight
Old Feb 6, 2012 | 04:18 PM
JZ's Avatar
JZ
G35 Coupe KY0
yea... one of the techs told me its pretty easy to swap, but thats coming from a guy that does it on a daily basis.
I smell antifreeze after i drive it so I have to take care of this ASAP!
Old Feb 9, 2012 | 11:29 PM
joedaddy1's Avatar
i am on the same boat @ 125k.. i can see something leaking.. damnit..
Old Feb 9, 2012 | 11:39 PM
03GT35R's Avatar
If you smell it, its most likely leaking...
Couple ways to know if its leaking..Do a visual inspection for dried antifreeze and-or overspray from your fan spraying it up on the bottom side of your hood.
Old Mar 5, 2014 | 01:15 AM
asingh1716's Avatar
But when should it be changed ? to stay in the safe zone
Old Mar 5, 2014 | 08:49 AM
coffeysm's Avatar
Is it making any weird noises? Mine went out at around 115k. There are two o-rings that separate the oil and coolant between the water pump. It's possible just those are bad, but I'd swap it anyway. It can be easy to do, but if you never did it before you can jack your engine up by skipping some teeth on the timing chain
I know this from experience, lol. I had to take the timing chain cover off and then decided to replace to guides and chain.
If you look under the car opposite the oil filter there are some weep holes where the coolant will leak from. Check your pil also to see if it looks like chocolate milk.
G35-2004-mt6
Sep 11, 2015 04:16 PM
spanky99l
Sep 7, 2015 12:46 AM
realtalk21
Jul 20, 2015 09:07 AM
anthraciteboy
Feb 20, 2007 09:49 PM
