Valve cover and seals help
Old Jan 31, 2012 | 06:51 PM
uttarpradesh's Avatar
I'm looking for someone who can help me with this. I'll pay not not dealer prices. I went to my dealer for an inspection and saw that my oil is seeping into my sparkplugs. I'm told I need to replace the seals and valve covers. Anyone able to do this for me for a reasonable fee? Thanks.
Old Jan 31, 2012 | 06:55 PM
JaE35's Avatar
Moderator
G35 Sedan
They should've fixed that crap for you for free lol i have the same issue..the best investment would be r&d factory, they sell modified valve covers that won't leak for 250...after you receive the new ones and send them your old ones they return 100 dollars to you so its basically 150. They're a vendor on here
Old Jan 31, 2012 | 07:05 PM
redpearl99's Avatar
The R&D seals havent held up for everyone
whoa, WTF they gave me an appraisal in the $700s for parts and labor! So if the valve cover is leaking they're supposed to fix it as part of the sparkplugs replacement? I never knew...
Old Jan 31, 2012 | 07:14 PM
faiz23's Avatar
Fail...
Old Jan 31, 2012 | 07:27 PM
redpearl99's Avatar
^1+ this entire thread is fail
Old Jan 31, 2012 | 07:43 PM
JaE35's Avatar
Moderator
G35 Sedan
wrong side of bed this morning?
Old Jan 31, 2012 | 07:44 PM
JaE35's Avatar
Moderator
G35 Sedan
https://g35driver.com/forums/vendor-...lve-cover.html
Old Jan 31, 2012 | 07:46 PM
redpearl99's Avatar
Actually no, woke up on the right side...but i did wake up to my stupid cat walking on my face
Old Feb 3, 2012 | 12:40 PM
onevoice's Avatar
Is your car having performance problems?
If not, then just soak up the oil from the spark plug tube and drive. And just check for the oil every once in a while
Old Feb 3, 2012 | 12:45 PM
Frankieg35's Avatar
Check the marketplace.. there is a set of new valve covers and gaskets fs for $300..
Old Feb 3, 2012 | 01:51 PM
My thoughts exactly. I was just thinking this last night. The guy at dealer said that as long as it doesn't cover over an inch of the plug, it's still driveable.
Old Feb 3, 2012 | 02:01 PM
This would be a long term solution. Thnks
Old Feb 3, 2012 | 02:46 PM
JaE35's Avatar
Moderator
G35 Sedan
i wouldn't advise buying another set that will just fail again eventually
Old Feb 3, 2012 | 05:09 PM
UCIMAplaya2's Avatar
I just got the DIY overhaul kit from R&D factory. For $100 you get the seals, a new oem pcv with oem seal, and oem gaskets. for $60 you can just get the seals. Those are the prices including shipping. Not cheap but at least you dont have to buy new valve covers. I got a used set of valve covers and bought a 1 & 7/8" hole saw from ace hardware and cut the old ones out. Once the old ones are out (if you cut the holes centered) you are left with perfect sized holes to insert the new ones like you would on any other valve cover with replaceable seals. Mine came out great. I painted them too before putting the new parts in. As long as you take your time and get the holesaw centered they should come out great and you shouldn't have any issues. I made an insert to wedge into the holes to center the holesaw. The cool part is with the 1 & 7/8 hole saw, the hole you cut in the baffle to get the old ones out and insert the new ones, does not penetrate into the area where the baffle is plastic welded around the holes. Hard to explain but basically you dont end up with a baffle that is any less effective. Just channels to place the new seals into still separated by a wall.
