my NA build progress
Old Feb 6, 2012 | 01:27 PM
MikeGrote's Avatar
vq non rev
96mm cosworth 11:1 forged pistons
eagle Hbeam forged rods
ARP main studs
HR head gaskets and head bolts
ACL race series bearings
BC stage 2 cams
ferrea 6000 series stock sized valves
supertech dual valve springs
MD 1/2" plen spacer
worked nonrev lower plen
worked upper plen, specifically gasket matched to the tb
nismo Rtune headers
megan v2 test pipes (considering getting different ones)
MD resonated xyz Ypipe
DMH electronic cutout
stock midpipe and muffler
mishimoto radiator
edge racing 3200 stall torque converter (im auto)
revup oil pump
ATI dampner pulley
pathfinder cooling mod
water jackets machined
rotating assembly balanced
headwork by headgames
OEM injectors cleaned
headers and tp jet hot coated
all intake pieces gasket matched
polished crank
Old Feb 6, 2012 | 01:31 PM
jcseven7's Avatar
Sick. In for numbers!
Old Feb 6, 2012 | 01:38 PM
citymunky's Avatar
Nice to see a clean NA build.
Old Feb 6, 2012 | 01:42 PM
JaE35's Avatar
Moderator
G35 Sedan
Do fast intentions test pipes for sure
Old Feb 6, 2012 | 01:46 PM
MikeGrote's Avatar
why the fast intentions over the megans?
Old Feb 6, 2012 | 01:49 PM
JaE35's Avatar
Moderator
G35 Sedan
flex joints on the megans are almost garunteed to fail and cause nasty rasp at high rpm's...just low build quality overall...FI test pipes are probably only second to art pipes, sound absolutely amazing
Old Feb 6, 2012 | 03:11 PM
MikeGrote's Avatar
are they resonated?
Old Feb 6, 2012 | 03:13 PM
MikeGrote's Avatar
$400 for test pipes?!
Old Feb 6, 2012 | 03:22 PM
chink-ah-saur's Avatar
Numbers?
Old Feb 6, 2012 | 04:24 PM
MikeGrote's Avatar
i dont have numbers yet, i just started it for the first time last night. i still need to install the cutout and some other items. need to redo my nitrous setup before i get a tune
Old Feb 6, 2012 | 04:47 PM
JaE35's Avatar
Moderator
G35 Sedan
yea they're resonated..paying a quality premium for these i'll let others chime in
luger303's Avatar
looks great, congrats. Post up more pics and #'s when you can.
Old Feb 6, 2012 | 05:00 PM
MikeGrote's Avatar
you want pictures? i have lots of those! lol
Old Feb 6, 2012 | 05:11 PM
MikeGrote's Avatar
Old Feb 6, 2012 | 05:26 PM
Frankieg35's Avatar
Is your plenum polished or pc??
