03 6MT G35 Start Up Probs
Old Feb 11, 2012 | 03:15 PM
Xx AzN xX's Avatar
ok so i noticed this problem with my rpms dropping and shutting the car off and a thumping sound. I have z tube, and nismo axelback, and megan Y pipe. 64K miles.
This only happens after a drive. After driving and turning the car off, right when i try to turn it back on again, it cranks, but the rpms drop down under 0 and the battery light comes on for a split second and then it catches itself and they go back up to normal. (Somes times it just stalls out) I also here like a thumping sound, (Sounds like an exhaust rumble from an idle.) The thumping/rumble sound also happens after a drive. (I changed the battery and it still does this) At an idle the car is fine and steady.
Whats wierd is that from a cold start, the car starts up and there fine. and there is no thumping sound. But right after a drive around for 30 seconds, (driving normaly) the rumbling comes, and if i shut the car off and try to turn it back on it will almost try to stall out.....
here is a video, for some reason the sound quality is really low but if you used headphones you can here the thumping.
Please help Thanks.
Old Feb 14, 2012 | 08:28 PM
Drewer's Avatar
Try cleaning your MAF and throttle body. I had similar start up issues, and think it was because I recently oiled my filter and didn't let it completely dry, so my TB and MAF got a bit gummed up.
Old Feb 17, 2012 | 06:23 PM
Xx AzN xX's Avatar
I already tried those but it still refuses to get back to normal rpm after a warm start up
Old Feb 17, 2012 | 06:24 PM
Xx AzN xX's Avatar
and i also disconnected the battery for ,more than 6 hours. still a no go =[ im going to bring it in soon though
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
laksjd84
Jul 24, 2015 05:12 PM
kenthung
Jul 21, 2015 05:56 AM
