Clutch sits on floor after ACT clutch install
Old Feb 28, 2012 | 01:14 AM
SuperG118's Avatar
Alright so I just swapped my stock clutch for the ACT hDsS clutch and street flywheel and ss clutch line. I got everything back together and I am bleeding the clutch and the pressure has increased slightly but the clutch only returns out about half way.
I checked for any leaks and I have bled the clutch for almost and an hour and nothing...can't get it to return fully.
I heard maybe moving the pin out on the master cylinder? Any ideas or is that a good idea?
Thanks as always.
Old Feb 28, 2012 | 01:16 AM
Frankieg35's Avatar
Are u bleeding it with a machine or pumping the crap out of it??
Old Feb 28, 2012 | 07:04 AM
SuperG118's Avatar
Pumping the crap of it...I think I saw in the manual to not use any pressure bleeding systems.
Old Feb 28, 2012 | 10:21 AM
SuperG118's Avatar
Should I use a pressure bleeder? If so what one would you recommend for our cars?
Old Feb 29, 2012 | 01:11 PM
SuperG118's Avatar
Update: bled the clutch for almost 2 hours with pushing on the slave cylinder a couple times to make sure it was fully extending and compressing. Pedal now returns fully but still mushy at top...if I drive on the highway and not use the clutch, I can push it in and it feels perfect...but if I use it while city driving the pressure is weaker but again comes back after not using it for awhile.
Do I just need to bleed it more or maybe the clutch master cylinder bad even though it was okay before clutch install?
Old Feb 29, 2012 | 05:14 PM
TannerG's Avatar
What did you go with for fluid?
Old Feb 29, 2012 | 06:52 PM
SuperG118's Avatar
Some dot 4 from autozone.
Old Feb 29, 2012 | 07:49 PM
g-adabout's Avatar
Mine was the same way after my ACT install. Just drove it for a while and it came back to its natural location and never pumped or bled the system. I now have over 6k miles on it and I havent had any issues with it and while it is stiffer than stock, I do love my clutch.
I hope everything works out!
Old Mar 2, 2012 | 05:13 PM
SuperG118's Avatar
I have almost 300 miles on the clutch and it is so inconsistent its killing me. I have the clutch adjusted all the way out so it should be releasing high but some times it releases an inch off the ground and other times near the top, I don't get it. I'm going to try and bleed again and maybe take apart the master cylinder.
11bEMT
May 27, 2022 03:13 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
zcherub
Aug 30, 2015 05:04 PM
EPG35
Aug 16, 2015 04:52 PM
