HELP!!!!! Coil Pack Mounting bolt snapped off
Old Mar 18, 2012 | 02:53 PM
Steve WIlson's Avatar
So I was changing my plugs this morning in an 05x, and I got to the drivers side rear plug, closest to the firewall.
As I was taking the bolt loose, it snapped off and half the screw was still down inside the threads. After a couple hours or trying to drill the screw out, I was unsuccessful and ruined the brass threads the bolt should have screwed into.
The coil pack sits down in how it should fine, but is a bit looser than I would like. There is a metal bracket for all the wiring that sits over top of it, but not close enough to put pressure on the coil pack and hold it in place.
Couple questions:
What is the black "headcover" piece called, if I wanted to buy a new one or get used?
Is it safe to drive? I started it up and it runs fine, not chugging or missing at all.
Or, should i just jam something between the metal bracket and the top of the coil pack to hold it in place.......... actually kidding
If I drive it for a few days or at least to drop it off at the dealer tomorrow is there a risk of fire? The last thing I need it for it to catch fire.
Please help!!!!!!!
Old Mar 18, 2012 | 09:49 PM
herrschaft's Avatar
Highly doubt it, the last time one of my coilpacks was loose all it did was cause that cylinder to misfire.
Old Mar 18, 2012 | 10:00 PM
alfhasg35's Avatar
valve cover
Old Mar 18, 2012 | 10:23 PM
I've been trying to find the DIY for the valve covers for over two hours. Search isn't finding it or I'm just slow. Could be either. Do you know where that's located??
Old Mar 18, 2012 | 10:41 PM
alfhasg35's Avatar
which one you looking for..??
https://g35driver.com/forums/engine-...ent-again.html
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Claudiu
Sep 26, 2015 01:04 PM
doakley92
Sep 25, 2015 12:58 PM
Claudiu
Sep 24, 2015 01:12 PM
