NEW!!! SOHO Motorsports Single Turbo Kit!
Old Feb 6, 2013 | 03:39 PM
  #46
That's G's Avatar
Originally Posted by Kevin@Soho
All it takes is one of you kind fellas who have asked, to come on down and we will put it on! haha Just shoot us a pm if your interested! Thanks guys for the support!
I wish you guys weren't all the way on the other side of the country or I would drop all things in life to come get this put on and tested!
Old Feb 6, 2013 | 05:28 PM
  #47
Infinite1's Avatar
20 Year Member
As I stated above, we would love a test car. If anyone is interested and on the east coast and willing to come to Charlotte then we can definitely work out a deal you cant refuse, just send us a pm if your serious about it.
As for the Mule Z it has about 50k on it, but with our kit on low boost your engine would be perfectly fine (assuming it has no issues now, obviously).
Well that rules me out...I'm in Houston...uggg..hahah...I found out about you guys from a 350z owner who recently installed this kit on his car.
No problems that I know about haha...I practically baby the car since it's my daily.
Old Feb 24, 2013 | 07:43 PM
  #48
Kevin@Soho's Avatar
Thumbs up SOHO Motorsports Single Turbo Kit w/ Motordyne Engineering Plenum Spacer Writeup
SOHO Motorsports Single Turbo Kit w/ Motordyne Engineering Plenum Spacer Review
This past weekend we had the opportunity to conduct a few tests on a DynoJet dynamometer with the Motordyne Engineering 5/16” intake manifold plenum spacer along with our single turbo kit on our 2005 non-revup Nissan 350Z. Previous tests that had been done with the SOHO single turbo kit were with the stock exhaust manifolds and no intake manifold plenum spacer, thus providing 392 hp and 406 ft-lbs of torque at a boost level of 8.58 psi. Nissan Engineers have done a phenomenal job designing the VQ35DE engine but as most of us know the stock plenum was not designed to its full potential. The plenum that comes on this vehicle from the factory was not designed particularly to aid in airflow in a forced induction system let alone any performance additions, meaning that that space inside the plenum is restrictive and detrimental to making horsepower.
Motordyne Engineering has done an excellent job of research and development on theri own in regards to the airflow restriction and benefits that can be achieved inside the VQ's plenum. With the addition of the 5/16 inch plenum spacer adding volume, the initial pressure drop that is inside the plenum is reduced by a factor of 9, thus increasing the overall airflow inside the plenum. With increased airflow comes an increase in the horsepower capabality. In previous tuning sessions with customer cars on NA setups along with plenum spacers we have seen good increases in horsepower numbers as high as 10-15+ rwhp. When we decided to add the spacer to our 350Z with stock manifolds and our turbo kit we were expecting good results and the goal was to see how low of boost we could run to make the same near 400 numbers that are common on daily driven setups in an effort to strain the motor even less than the very minimal amount it already does. As you can see in Figure 1 below, the two graph lines represent the SOHO turbo kit with no plenum spacer at boost levels of 5.82 (red) psi and 8.58 psi (blue).
Figure 1.
As you can see in Figure 1, in order for a 10% increase in horsepower and torque there is a 32% increase in boost pressure that is required, thus more stress on the engine internals. After installing the Motordyne Engineering 5/16" plenum spacer and some quick tuning of the stock computer with the aid of UpRev Osiris, we saw a drastic increase in power and a drop in necessary boost pressure to achieve almost the same power levels at nearly half the boost. In Figure 2 below, these were the horsepower and torque values that we achieved with only the addition of the 5/16” plenum spacer, and in Figure 3 you can see the comparison of horsepower numbers against the dynamometer pull at a boost pressure of 8.58psi.
Figure 2.
Figure 3.
There was around a 9 rwhp and 14 ft-lbs difference between the two dynamometer pulls at SAE but there was a 45% difference in boost pressure to achieve these values. The plenum spacer definitely allowed the engine to breathe much easier and thus aided in creating incredible power at such a low boost pressure. This is a great discovery that we found on the dynamometer because it takes a substantial amount of stress off of the engine internals and allows the engine to operate at a more efficient level. With the addition of the plenum spacer we were able to achieve an incredible 26.21 horsepower per pound of boost and 32.26 ft-lbs of torque per pound of boost, making this turbo kit even more so one of the most efficient kits in the market in terms of power and torque per pound of boost.
As a comparison for sake of argument, a few months ago we had a 2003 Nissan non-revup 350Z with stock exhaust manifolds that we installed a Motordyne Engineering 5/16” plenum spacer along with a comparable single turbo kit. In Figure 4 below you can see the comparison between the SOHO Single Turbo Kit (blue) vs the Momentum Single Turbo kit (red) on identical vehicle setups on the same Dynojet dynamometer and at SAE.
Figure 4.
The comparable single turbo kit, which can be seen in Run 11 (red), made great safe power for a stock daily driven block but required around 42% more boost pressure to make the same power as the SOHO Turbo Kit (blue). Many people may say that the turbo that we have chosen is the main reason as to why we make these values, which is a large factor, but the overall design of the turbo kit along with the Garrett GTX35R turbo that we have chosen is why we make such great power at such low boost. In the next few weeks we will be testing the SOHO single turbo kit on a fully built race motor with headers and we anticipate great numbers at lower boost pressures as well. For more questions on interest in design reasons or ideology please check out our technical writeup of the kit hhttp://sohomotorsports.com/turbo.phpere at http://sohomotorsports.com/turbo.php
Old Feb 24, 2013 | 11:03 PM
  #49
Kevin@Soho's Avatar
And a video to go with it
Old Feb 25, 2013 | 06:56 PM
  #50
That's G's Avatar
If I wasn't in the middle of trying to buy a house right now...
Old Feb 26, 2013 | 11:42 AM
  #51
Kevin@Soho's Avatar
House's can wait... build the car! It will be way more fun than a house thats for sure! haha
Old Mar 4, 2013 | 10:14 PM
  #52
Kevin@Soho's Avatar
Update on the kit: We have made some updates to our SOHO Single Turbo Kit for Z's an G's due to a fitment issue we had on a customer's Z with specific Momentum Headers. They seem to be one of most obtrusive manifolds on the market and are very cramped in the engine bay and therefore wouldnt allow for our downpipe to clear.We adjusted the downpipe and for installation purposes have switched it from one piece to two piece pipe via V-Band clamp. Here are some photos of the new down pipe layout that clears the Momentum headers. Momentum headers seem to be one of the obtrusive, closest to the fire wall and most space constricting manifolds we have seen so we believe it will clear most but right now only have verified with these. Here are some photos of the fab work in process at the shop, a few photos of cars and most importantly the layout and routing of the new two piece downpipe. Note: It is very difficult to take a proper photos of clearances with little lighting and very little room but clearance is good throughout.
Old May 31, 2013 | 07:51 PM
  #53
jojov's Avatar
Kevin, I'm looking at your set up and it looks like with this turbo kit the dual exhaust need to be converted to a single exhaust?
Old Sep 26, 2013 | 04:03 AM
  #54
Herbbie Hablib's Avatar
Ive been on your website and the pricing page is not working, can you pm me with the pricing on both kits.
Thanks
Old Sep 26, 2013 | 01:46 PM
  #55
boosted920's Avatar
still not available for 5at ? whats the price? this should fit a 03 sedan, correct?
sorry for all the ?'s
thnx
Old Oct 29, 2013 | 11:29 PM
  #56
RobV's Avatar
thnx
+1 on the 5at
Old Dec 13, 2013 | 01:42 AM
  #57
nitish21's Avatar
Subd to this...
Old Dec 13, 2013 | 06:33 PM
  #58
SlickSilverG's Avatar
7000 bucks? Why dont i just get a vortech.. lower the cost and i may be in one day..
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
Machine Head
Sep 4, 2015 07:22 PM
mikemf8
Sep 3, 2015 08:01 PM
