What needs to be done to my G35X
Old Apr 11, 2013 | 07:10 PM
deemo021's Avatar
hello everyone. I have an 06 g35X with 135000 k. ive had a car for a little over a year. I was wondering what I should look into getting done on the car around this mileage and age i.e shocks,belts... and what the cost would be. And should I put in a cold air intake? id love to hear your input. thanks
Old Apr 11, 2013 | 07:21 PM
gary c's Avatar
With 135K miles on her clock my first concern would be maintenance. Do you have receipts/records for the 100K mile service, all fluids/filers/plugs and probably belts? If you have the OE shocks on, the ride must be like an ocean liner. Forget the intake unless all the above mentioned service has been completed. Your G is good for at least another 100K+ miles if you take care of her!
Gary
Old Apr 11, 2013 | 07:27 PM
deemo021's Avatar
i bought it from the infiniti dealer so im sure everything is stock on it. im not sure what your refering to by OE shocks,sorry im an amateur at this.im going to my mechanic this weekend. how much would the filler plugs and belts run me? and should i look in to changing the shocks?
Old Apr 11, 2013 | 11:06 PM
jonavalos93's Avatar
i think Gary meant the filter. OEM shocks that means the Original Equipment Manufacture. So stock shocks, and the 2 belts and six spark plugs should run you under 100$ for parts. oh and the air filter should be around 20-35$ depending if you do k&n or a paper filter. Also theres a in cabin mirco filter under your passenger glove compartment and that i believe is around 15 bucks. all you can change on your own look up the DIY's on here
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
