04 g35 coupe ecm communication
Old May 6, 2013 | 07:44 PM
plopez's Avatar
I need some help with my g35 Flood I replace the ECM,BCM,IPDM AND THE VDC module, my problem is that I have communication with BCM AND IPDM but not with the ECM . I check can low and can high system for ohm and voltage and look good I check power to the ECM plug and GRD and I think its fine, this is my 2sec ECM and nothing..
I think that the ECM its not bad because I had communication 1 or 2 time for like a minute and that it no more after that, I still have communication with BCM AND IPDM..
CAN LOW = 2.3v
60ohm
CAN HIGH= 2.5v
CAN LOW = OHN TO GRD 1.2K.OHM with negative disconnected
CAN HIGH= OHM TO GRD 1.2K.OHM with negative disconnected.
i don't know what else to check... fuse and relay are good
thank you for the help
Old Jul 14, 2013 | 07:42 PM
mrathell's Avatar
How did you test the CAN? Visually how did you know it was the CAN lines?
CAN LOW = 2.3v
60ohm
CAN HIGH= 2.5v
Old Jul 14, 2013 | 09:11 PM
rcdash's Avatar
Try a new matching ECM off ebay...
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
mjfenix
Jul 14, 2015 10:37 PM
