G35 transmission question
Old Aug 8, 2013 | 02:04 AM
Nirvana's Avatar
Do you guys like your transmission? Is it somewhat smooth? Are there any problems with it? How easy is it to go from first to second? I have only driven civic's and there tranny's are amazing so im not sure what to expect from something other than a Honda. Do you like your tranny's?
Old Aug 8, 2013 | 02:50 PM
livinglegend's Avatar
Go test drive one? If your idea of an amazing tranny is in a civic then you sir have low standards.. I like mine. If you are proficient at driving a manual its fine. People complain a lot about the small window of engagement in the clutch pedal but once you get used to it, its pretty much a non-point. It's a pretty solid transmission. Going from 1st to 2nd is as easy as you make it. If you're trying to paul walker the **** out of it then it will probably start to give you problems.
Old Aug 8, 2013 | 04:59 PM
Nirvana's Avatar
When i say amazing, i'm describing how smooth every gear is. I'd like to test one, but there are none at any of my local dealers thus far. Im in Victoria BC, on the island so it's rare to come across 6mt. But if i read your response right you're saying that it;s a learning curve. Once you get it down, you like it?
Old Aug 9, 2013 | 10:25 PM
JKL1031's Avatar
oh 1st-2nd-3rd is gonna jerka derk yah if u dont ease off clutch and give gas. no one knows what it is.
Old Aug 15, 2013 | 10:37 PM
wallofgrath's Avatar
G35 transmission is tough but smooth, it feels great. But my input shaft bearing went bad and whines, expensive fix, and I heard it's common.
Old Aug 17, 2013 | 02:59 PM
Stillen06coupe's Avatar
the jerkage is due to the electronic drive by wire, imo...... first car ive had with it, and its the only one that was somewhat difficult to learn to drive
Old Aug 19, 2013 | 05:24 PM
its not that its much of a learning curve, Its just like driving any other manual, but the window of engagement is a lot smaller than most cars so it just takes a little getting used to. Once you have the muscle memory its just another clutch
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
nervseele
Jul 17, 2015 11:21 PM
