75mm NWP throttle body is in
Old Aug 24, 2013 | 12:52 PM
butkiss1's Avatar
Im officially done with all engine mods!
All i can say is it pulls much harder above 5000
Old Aug 24, 2013 | 01:37 PM
HotRodG35's Avatar
LOL I said that years ago and still finding unique mods to do.
Old Aug 24, 2013 | 02:43 PM
herrschaft's Avatar
What do you mean done, I don't see a turbo in that engine bay yet
Old Aug 25, 2013 | 07:36 AM
Hogbone's Avatar
Have you do any dyno testing Sense you added the bigger TB?
Old Aug 25, 2013 | 08:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
I'm cranky because I should have had mine Thursday but NWP shipped it to the wrong address. Anyhoo, looks great B, have you had it on long enough to see any changes to your gas mileage? I'm guessing I'll have mine sometime this week and HotRod you're right, those of us with the addiction are never done lolol.
Old Aug 25, 2013 | 11:10 AM
butkiss1's Avatar
^^Come on J you know I'm all about naturally aspirated
^ When I get back in town probably in like 2&a half weeks I'll hit the DYno
Old Aug 28, 2013 | 08:31 AM
Blue Dream's Avatar
Any answer to the gas mileage question? Just curious.
Old Sep 4, 2013 | 04:50 PM
Frankieg35's Avatar
Is the inlet on the upper plenum 75mm also??
Old Sep 4, 2013 | 10:28 PM
herrschaft's Avatar
No, either 70 or 72mm
Old Sep 4, 2013 | 10:38 PM
Frankieg35's Avatar
So to do this mod right you‛d have to get the plenum machined??
Old Sep 4, 2013 | 10:44 PM
Urbanengineer's Avatar
Time to forward this question to NWP and MOTORDYNE for some upper plenum aftermarket increases...!
Old Sep 4, 2013 | 11:15 PM
SDGenius's Avatar
no, the adapter tapers back down
Old Sep 4, 2013 | 11:17 PM
herrschaft's Avatar
^He's talking about not having any choke points.
Old Sep 5, 2013 | 12:05 AM
SDGenius's Avatar
the difference in the pressure drop is where the gains are
Old Sep 5, 2013 | 05:19 AM
HotRodG35's Avatar
Inlet to plenum is 70mm and will also require welding up and redrilling holes because of the slightly wider bolt pattern.
Welded up and re-drilled holes on my SSV for a direct fit. Also required widening the SSV TB flange from 72.5mm to 75 mm.
I too did not want any restrictions, one of many reasons did not use NWP adapter.
