Must drain my gas help!!!!!!!!!!!
Okay, my car has sat just over a year. I treated the gas, but its coming up to the point where I just have to drain all the gas out of the car. I have tried to syphon it, but thats not happening. I just cant get it to go. SO..... I need help in a big way. Anyone else have ideas. I need to get all the old gas out and put fresh gas in so I dont ruin the car when I turn it over to the tuner in a few months. Any help would be GREAT!!!!!!
Where the fuel pump is? I just discovered that. Either way I need a drill pump. So tomorrow I will buy a pump and get it all out. This will be a future reference for everyone on here haha.
I run on biodiesel so my trunk is full of fuel... Not like that trunk holds anything else useful!
There are 2 metal lids with 4 plastic screws that hold them in place under the driver and passenger side rear seats. They aren't separate tanks technically speaking. it's 1 tank.
If you can access the fuel pump relay than jumper hot wire to trigger it. Assume since FI you have a fuel return, just disconnect line a convenient location and run to gas can for draining.
I do have a fuel return line, but its on the back of the plenum. Just so anyone knows, as stated before its one tank, but you have to access it from both sides. The passenger side is the one with the actual fuel pump in it. The drivers side is just a livel sensor. I'm almost done draining but I use a drill pump, and it broke. 4 dollar part.
Pieces you need
1-3 drill pumps They burn out.
A hose
Drill
Philips screw driver
Patience
Pieces you need
A hose
Drill
Patience
