03 g35 weird cam position sensor problem
Old Oct 8, 2013 | 07:14 PM
lowdown89's Avatar
Ok guys , the other day while driving our 03 g35 sedan it just cut off, hard to start back and was showing the vdc/slip light was on along with the service engine soon light... Ok figured it was the Cam sensor so. Scanned it and it was showing bank 1 so I ordered one from rock auto and just put it in. Cleared all the codes and upon start up it was still hard to start but not as bad as before, I drove the car around a little bit cut it on and off a few times and it still was a little hesisitant on start up. Went and parked the car for a few and re started it and damned if the vdc/slip light is back on and so is the service engine light and when I check the codes it is showing the bank 1 cam sensor again... The sensor I used is a Delphi has anyone had problems with bad sensor from them right from the box? Thanks in advance for any help guys!
Old Oct 8, 2013 | 08:50 PM
Lartytiejdke3's Avatar
best sensor is an OEM sensor.
Old Oct 11, 2013 | 11:53 PM
Jtrain's Avatar
OEM sensors for sure. But I'd rather get them from some place you can keep returning until you get one that works. If this ACTUALLY is the problem-- it's pretty well known just replacing it once will almost never work. Took me about 6-8 to fix my issue.
To be fair, I had a bunch of other **** going on. A list of mods would be helpful if you got something major going on (ie boost / ecu)
chinee
Jun 10, 2024 07:48 PM
R350k5
Oct 1, 2015 08:41 PM
Joshua615
Aug 31, 2015 12:29 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Thaaa_king
Jul 18, 2015 05:56 PM
