Coolant Drain question
Old Oct 12, 2013 | 06:59 PM
fflip's Avatar
Hello,
I am draining my coolant using the screw underneath the car, and noticed that only about 1.3 gallons came out of it.
Previously all my cooling heating worked fine so I assume the system was filled correctly.
Is this amount normal? I believe some amount may be trapped in the cylinder block and maybe the heater?
Thanks,
Andrew
Old Oct 12, 2013 | 07:10 PM
joeb1983's Avatar
G35
Exactly! You just drained your radiator via the petcock. Still coolant in the block.
Old Oct 12, 2013 | 11:57 PM
fflip's Avatar
Is there another simpler way way of draining it more than that?
Old Oct 13, 2013 | 12:38 AM
joeb1983's Avatar
G35
I personally do not drain the block entirely... Too much of a pain. I pull the lower hose off the radiator and it allows some of the coolant out the block to drain out. Here is a good read if your dead set on a complete system drain. If you do go that route make SURE you get all the air out of the system.
https://g35driver.com/forums/g35-cou...ain-plugs.html
baker2795
Sep 2, 2015 06:00 PM
Blakearold
Aug 27, 2015 12:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
