NWP75mm throttle body 15hp- Still not convinced
Old Nov 4, 2013 | 08:19 AM
ARETHT3's Avatar
Hi peolple wondering if there is any updates on these kits. Its been a cpl of months since the last comments on these and still no solid answer (please no guesses or scientific stuff about why it wont work.. This will be my last breather mod before i uprev tune and wanting to know what ppl have achived. Worth it???
If they worked i dont understand why they arnt getting raved on about.
http://www.nwpengineering.com/Phenolic[/FONT][/SIZE]_Spacers.html#BBTB[/FONT][/FONT]
Old Nov 4, 2013 | 10:23 AM
seymore4's Avatar
m56
I too am on the fence about these. Haven't tuned a car with one in person and I have seen no definitive proof (before and after dyno sheets, etc) so I'm with you in the wait n see crowd
Old Nov 4, 2013 | 11:00 AM
OBsessed's Avatar
If you're planning on tuning anyway (and you should be), upgrade the intake tube to a 3.5" unit. Changing the MAF housing will require a retune anyway, but it makes a good difference in air flow. Just opening up the TB size still limits you to how much air can get through the tube. It'll help, but it's still not "done" imo with a stock sized tube.
I don't have before and after numbers, I've changed too much and never did a before anyway, but I'm happy with mine. I'll be trying to get in on a local dyno day the next time one pops up and I will post whatever the results are, but can't help you until then.
Old Nov 5, 2013 | 10:26 AM
ARETHT3's Avatar
Thanks for replies anymore solid evidence?
Old Nov 5, 2013 | 05:55 PM
Tolboothwilley™'s Avatar
I haven't seen enough info yet either - hoping that someone will finally post something to convince me
Old Nov 5, 2013 | 06:56 PM
SDGenius's Avatar
everyone I've seen who's gotten one has "raved" about it, including me
Old Nov 6, 2013 | 04:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
Me too, I don't have any empirical proof it added power but it has made the car more fun to drive. Worth the $$ IMO. Now I need to upgrade my MAF and intake tube. SMH I'll never be done with this car lol.
Old Nov 6, 2013 | 06:34 AM
OBsessed's Avatar
Without any empirical proof I know there will always be people who will doubt it no matter what else is involved. But I've got to say that for less than the price of an MREV2 it did a lot more for the response and feel on the butt dyno. I did the spacer/mrev/z-tube combo a while back and didn't get nearly the kick in the *** that I did on the NWP and over sized intake tube.
It will always come down to more air going in making more power out. And I don't think it's mathematically possible for a 5mm increase to create too much air for the OEM style plenum volumes.
The upgraded MAF/tube size really brought it to life though. I can't recommend that highly enough. JuicinJake did some logging with and without (with a different, but also similarly sized 3.5" tube on a modified stock airbox) and noticed that just upgrading the tube size gave him 6.5% more air flow over stock. His new tube and larger throttle body (pre-NWP kit, but same size TB) netted him 10% more airflow over stock. Remember the "dynoing the myths of intake mods" thread? The reason they all performed about the same is that they're all the same size. None of them are adding air volume.
I understand the skepticism but I'm also amazed that we've gotten this bad about it. I can't think of an engine offhand that hasn't responded well to more air coming in.
Old Nov 6, 2013 | 08:50 PM
saywat?'s Avatar
the opinions on my350z seem to be on the more opposite end of the positive spectrum. atleast that's how it seemed. I would really like to see hard data rather than "it feels faster"
Old Nov 6, 2013 | 10:22 PM
herrschaft's Avatar
I have yet to install mine so I can't comment on actual experience, but I do hold the opinions from those over on my350z with more weight. And yeah, most of them say its not worth it. To see the benefits from something like this you would need the entire intake setup redone, possibly plenum modification depending on how far your willing to go, the restrictions removed from the exhaust and a tune. Essentially a full bolt-on and tuned setup.
Old Nov 7, 2013 | 05:23 AM
HotRodG35's Avatar
Upgrade is more beneficial to forced induction setup.
The 15 HP gain is @ 6200 RPM which is the non rev-up power limit with stock cams. FI is still producing sufficient air flow to see greater top end HP gain.
Rev-Up would see slightly more HP gains on the upper RPM range.
Not disputing anyones butt dyno results, agree with OBsessed that other supporting mods needed.
Old Nov 7, 2013 | 06:28 AM
OBsessed's Avatar
EXACTLY! Why you would expect to see a 3" intake tube, feed through a larger than 3" Throttle Body making *** loads of power is beyond me. You're not opening anything up with JUST the throttle body. Feed it more air, and you're in good shape. Port and polish your plenum too, it's not expensive and will help. Removing restrictions from the exhaust should always be recommended, this is nothing new. If you run through a larger intake w/larger MAF housing, you will absolutely need a tune. If you're a non-revup guy, consider throwing cams in as well. This isn't about just "is the NWP worth it" this is "How do I get decent power out of my car." And part of that answer certainly includes a larger throttle body.
If you just throw on the larger throttle body, and do nothing else, you're just trying to suck air in through the same limited straw, it's not going to help you. It's like trying to use a funnel in reverse.
Marty @ RRydes may still have 3.5" intakes left, he was doing $265 shipped on them. Guys have logged up to a 6.5% increase in air flow with JUST a 3.5" intake (on stock throttle body). If you expect your z-tube to do too much you'll be disappointed.
Old Nov 7, 2013 | 02:34 PM
Urbanengineer's Avatar
It is just the car isn't worth that amount of mods for its base value. A full breather increase isn't as much of a value anymore!
Old Nov 7, 2013 | 03:13 PM
jkuo's Avatar
The current price of the car has nothing to do with how much value a modification has. If people enjoy driving and modding their G, this may still be worthwhile. People still mod old Fox body Mustangs...
Old Nov 7, 2013 | 05:34 PM
saywat?'s Avatar
yea wat does the urban engineer mean by "its base value"...*hint this is ur chance to back peddle lol jp
