04 G35 6MT Engine power loss, please help!!
Old Dec 5, 2013 | 03:22 PM
NIROMU's Avatar
Unhappy 04 G35 6MT Engine power loss, please help!!
Hello everyone, I am posting this on here because I cannot find a solution anywhere and it is incredibly frustrating. I drive a 2004 G35 6MT with around 85k miles, and recently a few things have happened and I have lost power. about a month ago I was driving quickly, and all the sudden at around 70 my car cuts off while im driving and i had to come to a stop and restart it. It turned right back on and ran fine, but I have a power loss throughout the whole RPM band. No codes or check engine light have appeared though. I have brought it to a shop, and they checked the codes, TPS sensor, pedal position sensor, and the MAF sensor, since I asked them to, but could not find any problems with the car. They claim there are no codes and the car seems to be functioning properly. I have cleaned my MAF sensor with the proper maf sensor cleaner, and cleaned the throttle body, and they helped a little bit but have not solved the real power loss problem. Also, I have a loud exhaust on my car and have noticed it has gotten a little higher pitched and raspier in higher RPMs, like its running lean or something. I have also done the ECU reset procedure several times, and a throttle position open and closed reset procedure one time after the initial problem. My olny mods are an air intake, and true dual exhaust with an x pipe. The problems I am having did not occur when I installed these mods. A couple of weeks ago, my car started to run hot, and I stopped and turned the car off before it got too hot. After taking it to a shop I found out my thermostat and housing were going bad so I got them replaced, along with a radiator flush and new fluid, and that problem is gone, but my power loss problem is still there. So far, nothing has helped and im stuck with a slower G35 and cant fix it, so im sure all of you g35 drivers can relate to how that feels. Any ideas? any help would be greatly appreciated.
Old Dec 5, 2013 | 04:09 PM
Lartytiejdke3's Avatar
I had the same sort of power loss as well. It was my camshaft position sensors going bad/already went bad. I replaced it and everything was back to normal. Only difference was I had check engine lights on prior to the repair
Old Dec 5, 2013 | 04:27 PM
NIROMU's Avatar
Interesting.. how much did they cost to replace?
Old Dec 5, 2013 | 07:25 PM
I had a shop do mine only because I felt it was more of a wiring issue(which it wasn't) they pretty much just unplug and come out-then plug the new ones back in. Driver and passenger side. Very easy DIY though. Hardest part is just reaching them. Tight squeeze at times
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
