compass malfunction
Old Feb 8, 2005 | 07:07 PM
ebuy929's Avatar
compass malfunction
hello friends,
i just recieved my g35 back from the shop i had some minor repairs
evrything worked out great but for some reason my compass displays a dashed line like this; --- - - (close enough)
my dealer sed i have to make circles at 5 mph and hold the compass button down to reset it
however i tried and felt like an idiot because it didnt work
any suggestions?
Old Feb 8, 2005 | 07:55 PM
Brando's Avatar
Originally Posted by ebuy929
hello friends,
any suggestions?
Well.....you have to be IN THE CAR when you do those circles!!!! J/K....
Thats wierd!
Old Feb 8, 2005 | 08:06 PM
TINMAN's Avatar
did you circle cw or ccw? try the other direction now.also bump the speed to 10mph.
when first bought the car,went home and found out the compass didn't works.so i brought the car back to dealer and they told me that's what they did.
if it still not working then take to dealer and let them do it.
Old Feb 8, 2005 | 08:20 PM
Nismo7's Avatar
compass
The owners manual has the instructions on how to reset it depending on the "zone" you live in. Check there if you can't figure it out.
Old Feb 8, 2005 | 08:31 PM
ebuy929's Avatar
lol
yes i was in the car how long do i have to circle around for and where in the owners manual can i find the reset instructions
Old Feb 8, 2005 | 09:24 PM
dave's Avatar
According to page 2-6 of the owners manual:
If the compass unit does not receive any
correct signal for 10 minutes, the compass will
display the bar “-- -- --”. Have the vehicle
inspected by an INFINITI dealer.
If the compass displays the wrong direction, per page 2-8, do the following:
Correction procedure
1. Push COMP switch for about 10 seconds.
The direction bar starts blinking.
2. Turn off electrical equipment such as lights,
hazard indicator, air conditioner, etc. Then
drive the vehicle slowly (less than 3 MPH (5
km/h)) and turn the vehicle one or more
times in an open and safe area. When the
compass displays the direction, the procedure
is completed.
These page numbers are from the updated 2004 owners manual.
Old Feb 8, 2005 | 09:49 PM
ebuy929's Avatar
avoid
well ill try it tomaro but i hold the compas button while the engine is runing or when the batt is on?
thanx
Old Feb 9, 2005 | 12:41 AM
rmyers's Avatar
This just happened to me on my 05-6mt. I pressed the COMP button while my son was driving the car. I wanted to set the compass zone. All I got was the flashing -- -- -- lines. Yesterday I found an area I could turn around in and when I read the manual again it says to Press and Hold the COMP button WHILE turning the key to the ON position. After doing this, I drove the car around in circles 3 times, and still got the -- -- -- lines. So I figured I would take it in later. I traveled another 2 blocks to my original destination and when I parked the car, I noticed it was working.
So, turn the car off, then press and hold the COMP button WHILE turning the key to ON and then set your zone.
Hope that helps
Ron
Old Feb 9, 2005 | 03:51 PM
ebuy929's Avatar
thanx again u guys rock but heres the problem when i hold the comp button my lines dont flash it stays either regular dashes or off i cant get it to blink how do i do it please help
Old Feb 9, 2005 | 05:32 PM
ebuy929's Avatar
i tried everything but the -- -- -- does not blink
infiniti said to mess with it then do the circleing around steps but i cant get it to blnk
help please
Old Feb 9, 2005 | 05:40 PM
rmyers's Avatar
Did you try this?
Old Feb 9, 2005 | 05:48 PM
ebuy929's Avatar
yep i did that i turned the car off and when i trun it on it still tays solid no diffrence no blinks nothing infiniti doesnt know either im so mad
Old Feb 9, 2005 | 05:51 PM
ebuy929's Avatar
oh yeah and i held the comp buttton
Old Feb 9, 2005 | 05:55 PM
rmyers's Avatar
thanks for the clarification......if the car is under warranty, have them replace it......
Old Feb 9, 2005 | 07:39 PM
ebuy929's Avatar
here the problem i was in an accident and im scared to take it to the dealer even tho the car was fixed the compass is the only problem and its intact just needs programming......im just scared that they will blame this problem on my shop andy warrenty ............. any advice? maybe reseting my ecu helps?
