Stillen Engine Dampener Brace
Old Feb 16, 2005 | 08:44 AM
pdjafari's Avatar
so how 'smooth' was the install (if you performed it already)!!?? Was it worth the effort and did these install instructions help you??
Old Mar 25, 2006 | 08:56 PM
Tonys-G's Avatar
pdjafari
I hope you don't mind me jumping in here, but i have installed the stillen dampener a few months back and found it to be not that bad of an install
I would suggest pulling the radiator overflow take and pushing out of the way while you work on intalling the brackets, (don't need to disconnect the tank just move it out of the way). the only thing that might give you a little trouble is the "S" shaped bracket that attaches to the TCC
I found simple trick to mount this to get the screw to align correctly, take two pliers or vice grips an each end of ther clamp and bend them out (slightly) so as to straighten the length of the clamp.
this will allow the holes on each end of the clamp to align correctly with the holes in the TCC and the new dampener, so the screws do not strip, I think once you have it in front of you you will see what I mean.
if you try to force the screw into the bracket,dampener, and TCC it may be crooked and would start to crossthread, I noticed this right off when I started installing. by using the method I described the holes should line up perfectly.
(now some people have recieved their brackets that line up perfectly, so it all depends on what you get)
Old Jul 10, 2006 | 09:31 PM
425skyline's Avatar
^ I cant even get the damn screws off the TCC cover!!!
Freeman186
Sep 6, 2023 10:07 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
Joe Gargano
Sep 18, 2015 11:17 AM
Jnm07
Sep 5, 2015 01:16 AM
