Stillen Engine Dampener Brace
Old Feb 11, 2005 | 12:47 AM
kaigenx's Avatar
I have it....tried to install it. Usually I'm pretty good at installing things but this thing is a pain in the *** to install. Only cause it mounts pretty low into the engine bay....so it's just sittin in it's box right now till i decide to go get it put on.
Old Feb 11, 2005 | 08:13 AM
pdjafari's Avatar
Im not sure about the stillen but the Pro-1 looks just like the stillen and i believe it mounts near the power steering fluid, towards the front left side of the car in front of the battery. I believe Moog has the Pro-1 dampener and it looks pretty nice. I am curious as to any improve in acceleration this will aide in??
Old Feb 11, 2005 | 10:29 AM
kaigenx's Avatar
the stillen mounts underneath the power steering container(i think it's the power steering) here's a pic of the pro-1, the bottle I'm talking about is that little circular bottle thing next to the washer fluid.
anyways, you have to take it off it's bracket to get to the mounting point. The other side of the dampener mounts to some other place on the engine.
Old Feb 11, 2005 | 11:53 AM
pdjafari's Avatar
I PM'd Moog about this and he said he had to 'drill one hole' for this to install, and as you see in the pic it is attached near or onto the hood support near P/S as you mentioned. I would PM Moog to see where on the engine block this is mounted to. I do know that he said he had to drill one hole, not sure on which end....
Old Feb 11, 2005 | 12:34 PM
kaigenx's Avatar
hmmm.....the stillen one is a direct bolt on. No drilling needed
Old Feb 13, 2005 | 02:58 PM
waijai's Avatar
i.love.gold
Yeah it requires you to drill a hole. The whole install took me only 20 minutes or so including the time to drill and take pics along the way.
Old Feb 13, 2005 | 09:08 PM
amg35's Avatar
Florida G35 Club
Moog,
Did you notice any improvement from the installation of the damper? Did you notice any increase in vibration in the cabin of your G? Thanks.
Old Feb 14, 2005 | 05:48 PM
Brando's Avatar
I looked at those dampners also....
Actually when I had my car dynoed last month......I stood there and watched the engine, and thought to myself....it barely moves!
At 6k rpm and 130mph....there was very little torque twist at all.
So I think it is not something you need.
JMO
Old Feb 15, 2005 | 01:15 PM
waijai's Avatar
i.love.gold
JMO
Did the person operating your car on the dyno take it up WOT through the gears while you were watching your engine? I'm thinking probably not. Under real world load, the engine does twist. Of course this isn't something you "need", but it's a mod and people will use it.
I did notice a very slight increase in vibration through the pedal assembly. The car is smoother through WOT shifts.
Old Feb 15, 2005 | 02:17 PM
DaveB's Avatar
The purpose of the damper is to reduce twisting torque on the engine mounts at WOT shifts. In an G35 automatic, it's a waste. This tranny doesn't shift hard at all compared to the blazingly hard WOT shifts of something like an F-Body LT1/LS1. I'd kill to have my G35 shift like my 94 Z28. Smooth shifts around town and super hard at WOT (like it should).
Old Feb 15, 2005 | 02:38 PM
KORRUPT's Avatar
I have and installed the stillen myself.Big PITFA, took me 40 minutes to put in.It really changed the shifting dynamics of the car for the better, much smoother shifts.I notice very little vibration in fact I think it actually reduced the vibration in my shifter.I also installed the rogue short shifter and changed my fluid to the amsoil and now the shifts are smooooooooooooth.All in all i recommend it.
Old Feb 15, 2005 | 03:41 PM
pdjafari's Avatar
can you elaborate on what made it a PITFA?? A part I considered..but gave up on...just curious HOW hard install really is....
Old Feb 15, 2005 | 04:24 PM
pdjafari's Avatar
Bazz, please do...might just order it for the heck of it if install seems easy...
