2005 G35 Coupe 5AT Engine Knock
Old May 17, 2014 | 09:56 PM
jjcarrera100's Avatar
So...I had to replace my Y pipe the other day and before doing so, noticed the slightest sound of engine knock. So after replacing the Y pipe I changed the oil. I have always used synthetic 5w30 but figured I'll use 10w30 to see if that would make the slight engine knock go away. Bad choice (I think) Now, the engine knock is very constant while idling and even worse when revved up to 1100rpm after 1100 it seems to get quieter up until 2000rpm and then I can no longer hear it. Was this due to using 10w30 or something having to do with the Y pipe and the catalytic coverters? Also there is a faint burning smell. I'm going to drain the oil and put in 5w30 tomorrow to see if that helps any but in the meantime, any thoughts/suggestions on what it could be or what to do?
Thanks
Old May 17, 2014 | 09:59 PM
Urbanengineer's Avatar
Replace your gas. Maybe you had some bad gas.
Old May 17, 2014 | 11:21 PM
It shouldn't be that. I've only used Shell 91 for over a year now and never heard this noise until replacing the Y pipe and changing to 10w30. Took the car over to a large parking lot tonight, and while in drive and giving it a little bit of gas I could hear the knocking as well and it matching the RPMs.
Old May 19, 2014 | 01:38 AM
Tolboothwilley™'s Avatar
its not the oil - 10w-30 is good, thats what I use
if you actually have a knock consider other things...bad gas, spark plugs, etc
Old May 19, 2014 | 01:38 PM
I'm pretty sure it's a rod bearing. I haven't changed the plugs yet, but I used some Lucas Oil Stabilizer and it seemed to quiet down the knock.
laksjd84
Feb 28, 2026 01:58 PM
mike730
Jan 12, 2018 04:25 PM
Blakelyg35
Aug 15, 2015 12:12 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
