How much is the average cost for valve cover gaskets?
Old May 18, 2014 | 01:10 PM
g35fnatic's Avatar
So my mechanic found their was oil leaking onto my coils and spark plugs and told me I needed to change my valve cover gaskets, quoted me 500$ for it. is this overpriced?
Also got charged 200 to change 2 of my coils that was causing a CEL..
labor prices are so rape
Old May 19, 2014 | 12:03 AM
coffeysm's Avatar
I think for OEM gaskets those sound about right not counting labor. I know someone recently used Maxima valve covers with success. Those were about 100-200 for both I think, but you have to modify your intake slightly I think.
Old May 19, 2014 | 01:21 AM
hurleyguys's Avatar
500 is prob just for parts. cause you have to buy new valve covers from infiniti and it like 250 a side. plus labor. my mechanic i go to quoted me 1000 for parts and labor.
Old May 19, 2014 | 01:32 AM
Tolboothwilley™'s Avatar
you could remove the valve cover and try to use some RTV to seal it up
labor is about 2 hours probably - the valve cover gaskets are only $20 each but that isn't what is leaking, it is the part on the valve cover tubes which are not replaceable. Normally that requires replacing completely.
Old May 23, 2014 | 07:31 PM
Bonesntx's Avatar
MAXIMA Covers are the same except they say NISSAN or maybe MAXIMA.
Same engine = Same covers fit.
MAXIMA covers are about $40 per side. Infinity are about $100 per side.
As I understand you want to replace the coil gaskets at this time as well.
Check in the Vendor Section here I think you will find some to get MAXIMA covers.
That $500 sounds way good of a price for turnkey job. I'd like to be able to get it that cheap. When mine come due I will do it myself probably.
You cannot RTV them and expect them to stay sealed.
Here is quote from R& Factory Southern CA...I just received this so looks good for me to get parts from them. I will go to NISSAN first and check.
I so not know what these guys are tlaking about Grommets and Alignment Tool but surely needed.
1. with the gasket set with 6 grommet and pcv oring ,2 valve cover gasket and alignment tool it will be $129 shipped with usps priority .
2. just 6 of the grommet with alignment tool it will be $80 shipped .
eunosz
Aug 12, 2015 04:13 PM
eunosz
Engine - Complete Motors
Aug 11, 2015 08:35 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
yassy
Aug 9, 2015 07:31 PM
ghost_g35
Aug 7, 2015 10:31 AM
