Clutch Pedal not regaining pressure(Trouble with Bleeding)
Old Jun 14, 2014 | 11:40 PM
Polyphonic's Avatar
Hello, I've been working on replacing my clutch hose line. After reattaching the hose after draining all the clutch fluid, the pedal naturally had no pressure. After many times trying to bleed the clutch the conventional way, I have only regained enough pressure for the pedal to push a couple inches off the floor.
I also tried bleeding with a brake pressure pump, but when pumping with it, barely any fluid comes out of the bleed valve. Am I doing it wrong? Any tips. I've done over 30-40 reps of the conventional method with no improvement in clutch pressure. Are there any other ways to get all the air bubbles out?
dseet
Oct 11, 2015 12:40 AM
BradMD_96
Oct 6, 2015 09:31 AM
AL8782
Oct 3, 2015 10:26 AM
9tray turbo
Sep 29, 2015 10:22 PM
jbmw002
Sep 10, 2015 12:54 AM
