I need help installing a idler pulley delete kit.
Old Oct 24, 2014 | 02:18 PM
iloverice's Avatar
Please help me install my idler pulley delete kit. Website links or any form of help would be appreciated. Thanks
Old Oct 24, 2014 | 09:41 PM
coffeysm's Avatar
Search for the graphic from Z1. Basically, you take your belts off, hold the pulley in place (chain or strap wrench), unbolt the four small screws, and then take that bracket off. The little spacer goes on the top corner where that bracket would go and you reinstall th bolts in the block. Get some pb blaster and drench the pulley in it. Helped me a lot with mine.
Old Oct 25, 2014 | 06:30 AM
scottvt's Avatar
Not to be one of those dick bags, but this is the top result when I googled "G35 idler pulley delete" and its probably what your looking for.
http://my350z.com/forum/engine-drive...with-pics.html
Old Oct 25, 2014 | 06:39 AM
scottvt's Avatar
Scroll down to post #4 and he gives pretty clear instructions. For what its worth, I did this a while back, and the hardest part was getting the proper belt from the guys at O'reillys...
And you will need a spacer, ( it is a Nissan part, dont know the PN off hand) unless you cut part of the bracket off, like he does in the link above. Good luck, it looks way cleaner with it gone.
Old Oct 25, 2014 | 07:51 AM
iloverice's Avatar
Thanks guys I really appreciate it
flytim3
Jul 29, 2016 10:17 PM
EricF
Aug 28, 2015 08:27 AM
linedr89
Aug 17, 2015 05:11 PM
