Sucked water through turbo
Old Dec 24, 2014 | 03:51 PM
justaginger306's Avatar
well last night i was driving a friend of mine back onto base when a wild flood zone appeared. not seeing it in time due to it being night i smacked into the probably 8 inches of water tons smoke everywhere.
i got through it and the car idled ROUGH. soon however the idle began to smooth out and after 15 minutes the idle was fine i gradually revved it and the ecu let me past the safe mode range fine little bit of smoke came out bov then that stopped as well .
i babied the car onto base and then home let her sit over night to dry it out. today started fine worked fine however i noticed a lack of power in it so i figured i was getting a misfire it wasn't lacking hugely and there wasn't any large vibrations or anything but when i had it checked at auto zone i was reading a misfire on cylinder 2.
bought 6 all new spark plugs and will put them in before driving again. any other recommendations? did i just turn my engine into a time bomb? or am i okay? tips? things i need to check or do?
Old Dec 24, 2014 | 04:21 PM
Urbanengineer's Avatar
Time is the best healer. Just let the car sit a few days and let the water evaporate...
Old Dec 24, 2014 | 05:45 PM
thank you very much for the fast reply ill let it sit for a couple days think i should start it periodically or no?
Old Dec 24, 2014 | 06:41 PM
Noooooooooo. Merry Christmas let it sleep b
Old Dec 24, 2014 | 06:47 PM
good to go thank you very much for the help i hope there is no water left in the intercooler i will have to pull it off and try to blast it out when i change the plugs. sunday it should be good to limp to a shop right?
and merry Christmas to you too!
Old Dec 25, 2014 | 03:06 AM
redonblack35's Avatar
I dropped my phone in the sink once so I put it in a bowl of rice. Any chance you're in japan?
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
