Valves Covers Wich Route ?
Old Feb 2, 2015 | 11:57 PM
mannypr24's Avatar
Hi,
I have a leaking valve covers. I read about it, Choice #1 New OEM $420 pair
Choice #2 R&D Seals $130.00 Pair. Choice #3 Nissan Maxima 2004-2005 $150 pair.
All 3 choices had pros ans cons but wich you think might be the best option?
Thanks,
Old Feb 3, 2015 | 12:19 AM
herrschaft's Avatar
What was the difference with the Maxima's covers again?
Old Feb 3, 2015 | 07:56 AM
Urbanengineer's Avatar
Modifications are needed to make fit on the drivers' Side.
Old Feb 3, 2015 | 11:20 AM
Deepdiver's Avatar
If i were you, I'd go with the R&D Factory valve cover kit. I've been very pleased with mine. I've had it so far for two years, no leaks.
https://g35driver.com/forums/engine-...asket-set.html
Old Feb 3, 2015 | 08:52 PM
mannypr24's Avatar
[QUOTE=Deepdiver;6972556]If i were you, I'd go with the R&D Factory valve cover kit. I've been very pleased with mine. I've had it so far for two years, no leaks.
Good to know that you are pleased with the R&D kit. Do you do the work on your own? How time consuming is this job?
thanks!
Old Feb 4, 2015 | 10:44 AM
Deepdiver's Avatar
I didn't have to do the work. I took it to R&D factory and they had a set already made.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Hogbone
Sep 28, 2015 06:44 PM
