Leaky fuel damper after wiretuck/fuel mod delete
Old May 14, 2015 | 09:10 PM
dimentio1's Avatar
Hey all. Just fininshed doing my first wiretuck. went well except when I turn on the car it spits gas from the fuel damper on the passenger side. It never did that until i did the fuel bracket delete. It still leaks even though I put the fuel bracket back on, and it comes from the same damper. It spits out upward so idk if that means its the O ring or the damper itself. Any ideas?
Old May 14, 2015 | 11:30 PM
coffeysm's Avatar
Probably the o-ring once you pop that off it will never seal right again. Go to Harbor Freight and buy one of their o-ring kits for like 5 bucks. I bought the green nitrile set and matched up the sizes best I could. Haven't had a problem with it leaking since, I was testing my fuel pressure one day and came across the same issue.
Old May 15, 2015 | 06:43 AM
dimentio1's Avatar
thanks man. Ima try that, hopefully it works, got work at 12....
Old May 15, 2015 | 10:21 AM
dimentio1's Avatar
it worked thanks so much. I picked up a pack of metric o-rings @ autozone.
Old May 16, 2015 | 12:22 AM
coffeysm's Avatar
Glad it worked out for you.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
junon
Sep 5, 2015 10:40 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
