350z engine in G35 (not HR)
Old Oct 2, 2015 | 11:19 AM
BradMD_96's Avatar
Hi all,
I'm planning on swapping out the engine in my 2004 G35 AT coupe.
The one I have found is fitted to a 2006 350z
From what I've seen I have found all 03-06 G35 coupes have the same '282hp/269lbs.ft' engines.
I have seen there is the same VQ35DE but with '287hp/274lbs.ft' fitted to the 350z from years 2003-2005 and another with '300hp/260lbs.ft' from 2005-2006.
The engine in my car and the 350z are before the introduction of the RevUp engines.
What I want to know is will I be fine to swap in any 350z (03-06) engine - Hopefully the 2006 engine is not a problem? Would it work on my G35 ECU?
And out of curiosity is there actually any real variations with the 03-05 and 05-06 engines. I see the power goes up and torque comes down, is that just tuning?
I have searched and found a thread where a guy put in an 05 350z engine into an 04 G35 which is reassuring, but confusion comes from the two different power ratings on the 350z from 03-05 and 05-06. I guess I want to know if it's a 'straight swap' or if I'll need to swap parts over like ecu/wiring harness/etc
All help is appreciated
Brad
Old Oct 2, 2015 | 11:49 AM
Lartytiejdke3's Avatar
revups can be found in g coupes from 05-07 6mt's
sedans 05-066mt revup also
revups were at 298hp
that 350z from that year can very well be a revup if it was 6mt? are you sure its not?
Old Oct 2, 2015 | 11:51 AM
BradMD_96's Avatar
Yeah I need to find out if it is a MT or AT.
Are the revups with the HR instead of the DE or is that not a good enough confirmation?
Anyway to check this through the VIN numbers?
Old Oct 2, 2015 | 12:47 PM
no
de's were either revup or non revup.
hr came later and never hit g coupes.
you can tell whether its a revup or non revup simply by looking at the cam covers up front. easy visual test.
this is a revup
http://s7.photobucket.com/user/akhar..._0140.jpg.html
this is a nonrevup
http://s85.photobucket.com/user/moog..._0512.jpg.html
Old Oct 2, 2015 | 01:07 PM
BradMD_96's Avatar
Okay so the revups have the variable valve timing on exhaust (in addition to intake).
So if I were to fit a revup in my G35 Coupe, I would or wouldn't need the ECU from the Zed?
EDIT: I suppose I would as I'd need something to control the exhaust side...
Old Oct 2, 2015 | 04:03 PM
BradMD_96's Avatar
Okay so I've just found it is from a 2006 G35 Sedan not a 350z.
According to wikipedia, 03-06 coupes have 282hp engines (non rev) and the 6MT 05-06 have rev up.
The AT sedans 05-06 have the 282hp non revup engine too. So I should be fine, right?
Now this thread is sort of unrelated to what I'm doing.....but I'm sure it'll be of use to someone
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
rob dog g35 cpe
Lights
25
Mar 17, 2016 10:17 PM
itztwinki3
Lights
Oct 15, 2015 04:38 AM
Srinidhi
Aug 7, 2015 03:38 PM
