p1273 & p1283 - Need tune?
Old Oct 20, 2015 | 05:07 PM
SoGosu's Avatar
Hi Guys,
A few weeks ago my check engine light turned on for a p1273 error(A/F sensor 1 Bank 1). However, I tightened down my intake and reset the ECU which turned off the light. I thought everything was fixed but today my car threw a p1283 error code (A/F sensor 1 Bank 2). Is it possible that my car is running too lean due to the bolt on mods I have? I've done a lot of searching but there's no concrete answer on if a tune is the correct way to fix this issue. I do plan on getting one, but the nearest UpRev dyno tuner is 2.5 hours away. I'd appreciate any recommendations!
Mods:
Greddy EVO3 Catback exhaust
Berk High Flow Cats
5/16 Plenum Spacer
z-tube
HR Intake box
aFe Pro S drop in filter
Car: 2004 G35 Coupe 6MT - 90k miles
Old Oct 20, 2015 | 05:35 PM
ScraggleRock's Avatar
No, those mods wouldn't make you lean enough to throw a code. I would clean your MAF, and if the codes still pop up, change the A/F sensors.
Old Oct 21, 2015 | 09:05 AM
yosip1115's Avatar
I fixed p1283 a while ago by tightening up plenum bolts. Basically make sure you don't have any post-MAF sensor leaks. Focus on drivers side. That code is telling you more air than calculated is passing by the sensor.
Old Oct 21, 2015 | 09:18 AM
SoGosu's Avatar
Thanks guys. I'll clean my MAF and look for leaks this weekend.
Old Oct 21, 2015 | 10:06 AM
yosip1115's Avatar
Check with propane or brake cleaner easiest way to find vac leaks
Old Oct 31, 2015 | 05:20 PM
SoGosu's Avatar
I didn't want to mess with propane or brake cleaner so I just took everything apart and re-torqued all my plenum bolts. I also cleaned the MAF and throttle body while everything was out of the car. There's less hissing when I press on the gas now but it's too early to tell if I fixed it. I'll probably just take it in to a shop if my engine light comes back on.
Old Nov 28, 2015 | 08:48 PM
SoGosu's Avatar
Just wanted to post a followup in case other people have this issue. My check engine light hasn't come back on after about a month. Either cleaning the MAF or re-torquing the plenum bolts fixed it. Thanks for everyones help.
Old Nov 28, 2015 | 09:14 PM
yosip1115's Avatar
Fantastic that's why we're here! Happy cruising.
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
RA081024
Aug 18, 2015 07:03 AM
Raven7
Aug 14, 2015 04:40 PM
restrada
Aug 6, 2015 01:44 PM
