Not to sure whats going on.
Old Dec 14, 2015 | 07:21 PM
Carlos Chavez's Avatar
So I picked up payments on my boys 05 g35 coupe. He didn't take much care of it. The same weekend I got it I traced down a short because drl kept blowing out. Then camshaft sensor went out. So I replaced it was able to do it without removing the throttle body like some people were saying. I'm down to fixing the driver side window and the main problem a coolant leak.
Problem: the other night I was leaving the store mad sure the radiator had coolant. I live 1 exit off the freeway. When I was exiting the engine shut off on me. It didn't act funny temp didn't rise but when i came to a stop it was smoking. I towed it home. So that's when the camshaft code came up. I changed it. Now when i turn my key it does not turn over but sounds like it wants to start. Could this possibley maybe now be a spark issue? My neighbor said the spark plugs might have condensation. Is that a possibility? I'm going to pull the plugs out in the morning.
Old Dec 15, 2015 | 09:19 AM
VenomGT9's Avatar
Check the plugs, these motors are known for having oil seep through the seals/gasket...I'd looking into replacing the valve seals/gasket while you're there.
Was there still coolant when it started smoking? How about oil?
Old Dec 15, 2015 | 11:53 AM
SxExCx's Avatar
check crank position sensor too.
Old Dec 16, 2015 | 06:28 PM
Yes I had just added coolant when i got into my car. I didn't have a chance to pull my plugs out today.
Right now it almost sounds like maybe the starter is spinning my not engaging maybe.
I installed a brand new one. That code had showed up but now it's gone.
mbe32
Nov 12, 2015 06:50 PM
andre6191
Engine - Intake/Fuel
Oct 14, 2015 09:20 AM
Bdrago86
Oct 13, 2015 11:49 AM
mbe32
Oct 4, 2015 10:27 PM
Usman Ali
Oct 4, 2015 08:23 PM
