Oil leak
Oil leak
Hi i have a nasty oil leak i believe ut runs down ive been told numerous things such as oil pump or rear main seal i changed one valve cover on it already but noticed this because i was stil leaking what could it be a camshaft o ring? Or that gasket tothe pipe what is that pipe anyways?
Could it be leaking oil ftom here?
Hi i have a nasty oil leak i believe ut runs down ive been told numerous things such as oil pump or rear main seal i changed one valve cover on it already but noticed this because i was stil leaking what could it be a camshaft o ring? Or that gasket tothe pipe what is that pipe anyways?2003 stock
pclos76
Jan 11, 2016 01:32 AM
