Cam timing chain play
Old Apr 17, 2016 | 06:30 AM
Grummi's Avatar
Hi all doing my oil galley gaskets and noticed that my secondary timing chains have some play in them
Is this normal ?
I know the tensioner are driven by ojl pressure but these just seem really loose to me. They do tighten up if I rotate them briefly.
Drivers side
Passenger side
Old Apr 17, 2016 | 03:43 PM
HereKittyKitty's Avatar
Does it make noise at high rpms?
Old Apr 17, 2016 | 10:26 PM
Grummi's Avatar
No noise at high rpm. It did make a knock/tap type noise only at idle but I assume that is because my oil galley gaskets were blown out and I was seeing 12psi at idle.
Should I replace them anyway since I'm in there or do you think they are fine ?
WeinerXXX
May 2, 2016 01:04 AM
Grummi
Apr 17, 2016 02:33 AM
ChandlerL
Apr 14, 2016 01:57 AM
mjw011689
Apr 11, 2016 08:20 PM
350z006
Engine - Electrical
Apr 11, 2016 12:58 PM
