New Build daily driver 500 HP
Old Jul 25, 2016 | 08:16 PM
FATMANSAM's Avatar
Hi guys, im new to the forum, but I have been spending lots of time reading up on a few different things. I recently got a G35 04 coup 6MT, and I wanted to slap a turbo on it. i read the noobs thread and others on here and i had a few questions i wasn't able to find out. let me know if you think this would work or if i should change a few items.
the goal is the get a daily driver but i wanted it to be around 400-500 hp.
i was going to replace the short block with a built short block 81 compression ratio from one of the preordered sites. can i use the heads that come with the original heads (original engine has 90k miles on it), or are there a few parts that i could/should replace?
then i was thinking of a TT from APS (TT so i can reduce turbo lag and get boost quicker) or would a single turbo be a better choice cuz it might be less maintaince. and it would be cheaper?
fuel injectors i was thinking of Deatschwerks 600 cc (is that sufficient or is it too much)?
Thanks guys i really appreciate your opinions.
Old Jul 25, 2016 | 11:58 PM
herrschaft's Avatar
Read the info on my350z.com as well, much more information in their FI section that will help you decide on a kit. 600cc injectors will be adequate for 400-450whp. Stock heads can flow fine with upwards of 500hp. I ran stock heads for several years with 500+hp without issues.
Old Jul 26, 2016 | 10:24 AM
VenomGT9's Avatar
upgraded head bolts and cams would be beneficial as well.
Old Jul 26, 2016 | 01:58 PM
FATMANSAM's Avatar
I'm browsing around the my350z site a bit. I still haven't found exactly what I'm looking for just yet. But there is good info on there. I know APR makes good bolts, where can I find good cams?
