No start issue
Old Sep 26, 2016 | 06:10 PM
b_dupy's Avatar
No start issue
I just picked up my G coupe project yesterday, and as of now the car won't start. The previous owner slid the back end of the car into a curb, and he said since then the car won't start, but there was a code for a cam sensor before the wreck. I don't think this would cause a no start, and I don't think I hear the fuel pump. I checked for some kind of a fuel pump kill switch, but the general consensus is that only Ford vehicles had these. So, any suggestions?
Old Sep 26, 2016 | 07:49 PM
b_dupy's Avatar
Edit: I do hear the fuel pump priming, but the car still won't start
Old Oct 9, 2016 | 01:12 AM
erich2780's Avatar
Hi, have you checked your car with a scanner? It may be a whole lot of problems, but I would check for both cam sensors and knock sensor. Once that's done and the car still doesn't start it could be the starter. Just fixed this problem on mine.
Old Oct 11, 2016 | 09:33 AM
b_dupy's Avatar
Yeah I put a scanner on it, and it didn't return any codes. The starter is fine, the car will turn over until the battery dies.
Old Oct 11, 2016 | 11:06 AM
telcoman's Avatar
Veteran: Army
QUOTE=b_dupy;7077351].... I don't think I hear the fuel pump. I checked for some kind of a fuel pump kill switch,
So, any suggestions?[/QUOTE]
An internal combustion automobile needs:
1-Air
2-Fuel
3-Spark
Is there enough gas in the tank?
Did you try checking for fuel pressure?
My guess is you've got a fuel problem
Are you getting spark?
Telcoman
Old Oct 12, 2016 | 07:13 AM
b_dupy's Avatar
1-Air
2-Fuel
3-Spark
My guess is you've got a fuel problemAre you getting spark?
Telcoman
[/QUOTE]
I pulled the fuel line, but I can't check fuel pressure due to the fact that you need a special adapter for these cars, which I don't have at the moment. But the car is getting fuel. So I'm thinking yeah it's either injectors or spark. The car did have the passenger curtain airbag deploy, and I talked to a former Infiniti tech and he said that may be what's causing the car not to start, but I'm not 100% on that.
Old Oct 12, 2016 | 09:04 AM
coffeysm's Avatar
Check the cam sensors anyway and see if there is oil leaking around them. Does the red security light disappear when you turn the ignition on? Try unplugging the MAF or holding the pedal down while you crank.
jlr0042
V36 Engine, Exhaust, Drivetrain & FI
22
Mar 10, 2025 09:44 PM
rwdxtacy
Jul 22, 2016 09:08 AM
WHITE635
Canada
Jul 20, 2016 11:47 AM
Bean_VQ35DE
Jul 8, 2016 07:21 PM
Joyride
Jul 7, 2016 06:46 AM
