running ONLY larger injectors?
2004 6MT sedan.
I'm compiling all the parts for my S/C install later in February. Oil lines from Vortech are backordred. In reality it will be probably a month or longer before the S/C is up and running.
In the meantime I am going to replace the leaking valve covers and install my Kinetix manifold.
Since I have my 55cc injectors, can I install them now without doing the fuel pump and tune? It'll save me having to take everything off the top of the motor a second time.
IF you don't plan to drive, sure. If you do, no.
It takes me 10 minutes to get to the injectors... Start practicing if you're going FI haha.
I wouldn't recommend a plastic intake if you're going to be pressuring the manifold. Do you have the crappy plastic one or the pointless metal one?
