G35 Coupe LS3 swap Accelerator pedal
What would be the best Accelerator Pedal to use on a
G35 coupe LS3 / 6L80 DBW Swap.
I had a 2013 Silverado pedal but it can't fit properly and it's a composite
pedal so can't cut and weld it.
What did others on here use for the best fit?
Ls Swap Accelerator Pedal.
best place to ask is https://my350z.com/forum/engine-swaps-558/
I am doing a vk56de swap in my g and I am using the stock pedal.
I originally planned on using a 4.6l supercharged out of the xlr-v which used an ls3 type throttle body and it would have been u\easy enough to just connect the signlas.
Technically you don't need a special pedal, if you have a fly by wire car and a fly by wire motor, find the wiring for each and match the signals...
My 2 cents, but what do I know
Check out the 'G57 Sedan Build Thread.' Post #5.
https://g35driver.com/forums/media-s...ld-thread.html
G35Drew is doing an LS1 build. He is using S13 pedals. You might PM him for any insight he could offer.
Have you looked at 04-06 GTO's? My 06 pedal looks a lot like my G pedal but I have no idea if it would work. 04's had the LS1 and the 05-06's have the LS2.
